That looks pretty good there. Im bout to order an Injen intake anyday now. Cant wait.
The K&N with the AEM dryflow seems to have the best results....i.e. No CEL problems. Injen seems to be throwing CELs left and right.
AEM dryflow? Where can u get that from?
You can buy them directly from AEM's website
Here you go:
http://www.aempower.com/ViewCategory.aspx?CategoryID=93 Get an inner diameter measurement of your current filter neck or outer diameter measurement of your current intake pipe and match it to one on their list :) |
so between the injen and the fujita what is the best intake in terms of hp gains, sound, cel, intstall, and price? if u know of any sound clips could u let me know.
Originally Posted by jon_0_3
(Post 857908)
http://www.youtube.com/watch?v=Fh1IaHeXc5k Haven't heard/seen any Fujita setup cobalts though.. Injen shows the most gains out of the intakes for most cars to start with. the design "should" be the same if not, extremely similar in angles and tube routing for both Injen and Fujita. |
does anyone know anything about the weapon-r dragon intake? i seen one on ebay and i was just wondering if it was any good.
Originally Posted by Web
(Post 853838)
Here you go:
Originally Posted by SlayeR36987
(Post 860733)
Thanks man i appreciate it. Does it matter what type of filter i should get.
Originally Posted by stweed
(Post 858740)
Stick to Injen/K&N/AEM. |
www.f5air.com there dyno sheet on a cobalt s/c is 10plus on both hp and torque..and its the only 3 inch intake on the market...i bought it and i would receommend it over the others...
i need some help bought a injen intake from cobalt addiction
have everything installed correctly. but problem is the car will not run well at all. it seems to be going in limp mode. this with out driving it. any help will be greatly app. ps.have istalled a mass air flow sensor and runs with stock intake on |
Originally Posted by cleanupguy
(Post 867060)
(Post 867060)
will try it thanks a lot so very upset web
same car same color sweet |
Originally Posted by jeffrieckonfiyaaa
(Post 794363)
okay, after reading all of these posts and some on ss.com, no matter what intake i get, the CEL has a good chance of coming on?
because i want to either get the AEM of INJEN CAI, but dont really want to deal with the hassle of the light. |
Originally Posted by Boost Fr33k
(Post 869035)
i just installed the AEM dryflow intake yesterday, perfect fit, quite simple and sick sound. plus i went from hitting 13psi to 15psi @ 32 degrees. AND NO CEL
what kinda intake should i get for my ss/sc. also how big of exhaust should i get put on also u think 3 inch is to big
Originally Posted by Blue 05 SS/SC
(Post 875384)
For the exhaust, other's please correct me if I'm wrong on this: For S/C and N/A settings, you don't want to go much bigger than 2.5-2.75 inches inner diameter due to excess loss of pressure. In a S/C application (like yours), I would say 2.75 would be the largest I would go b/c you're still relying on the engine to produce the power and not the exhaust (just like an N/A). The S/C does help keep constant pressure in the manifold BUT, if you allow more and more exhaust gas to escape FASTER, the engine will be working harder to keep a constant pressure and be playing catch up. Now, turbos, those you want immediate exhaust exit b/c the power of the engine is manipulated DIRECTLY by the exhaust flow itself. That's why a lot of turbo cars have electronic/mechanical dumps right after the down pipe. The faster you can get the exhaust to escape, the faster the turbine can spool thus...creating more pressure in the manifold. For the S/C Cobalt, again, I would say no more than 2.75 inches INNER diameter for optimal performance. Anyone else got ideas? |
does anybody have the jbp intake cause i have it just havent installed it yet
as for the exhaust i have a custom 3" catback with
a 5.25 tip for about 3 bills i am having a fitment issue with my injen intake does anyone know which way the mass air sensor should point the little arrow on it mine points down stream toward the air filter any help will be app thanks |
(Post 877096)
There's an opening on the bottom end of the MAF Sensor one only one side of it. That opening should face the oncoming air...
I don't remember which way the arrow points. |
there a little arrow on the sensor and two on the sensor
bracket which is welded on the air intake pipe. the arrows on the stock airbox flow to the blower but the arrows on the injen to the air fiter wtf |
Who cares about arrows?
There is a hole on only one side of the sensor. The sensor can either be mounted with the hole facing the filter or the S/C. It's a functional sensor and for it to function correctly incoming air has to be directed into that hole. The hole must face towards the filter... |
