Stage 2 + 2.90 Pulley
Old Sep 13, 2007 | 02:48 AM
  #76
cblt12's Avatar
wow that sucks... i havent had any clutch problems but i do have a new one in my garage
Old Sep 13, 2007 | 12:35 PM
  #77
OniMirage's Avatar
Well put it this way blown4banger beat me when I just bought stage 2 ... literally beat me. From a roll at 60 since we were on the freeway and from all the info I have seen it would appear that a cai is WAY more than a couple horse power and I have seen dyno proof as well...
http://www.turbotechracing.com/produ...idproduct=2705
edit: and no im not kidding
Old Sep 13, 2007 | 12:58 PM
  #78
rukkee's Avatar
He must have a freek then .
Old Sep 13, 2007 | 02:38 PM
  #79
xravenwingsx's Avatar
JKennedy--where did you get your pulley from, and how much was it?
Old Sep 13, 2007 | 02:49 PM
  #80
JKennedy1612's Avatar
Nate...he fabricates them. It was $50 shipped
http://stores.ebay.com/NHERBST454-Pulleys
Last edited by JKennedy1612; Sep 13, 2007 at 02:49 PM. Reason: Automerged Doublepost
Old Sep 13, 2007 | 02:58 PM
  #81
R&C_rallySS's Avatar
Very nice write up. Mine should be here any day. I got my 2.9 from Anomlous or whatever from here for 40 bucks shipped. Can't wait to see the differance. Going to put dual pass and H/E on too. +rep For JFK!
Old Sep 13, 2007 | 03:09 PM
  #82
Good thinking...That might be my next mod also. Thanks
Old Sep 13, 2007 | 03:36 PM
  #83
QuikSilverSS's Avatar
a cai intake will do more for the car than a stage kit to be honest because the car with the cai will gain power quicker and boost will come much faster than a stage 1 or 2 car. I would go as far as to say a cai would be the same as a stage2 with a 2.9
I think you are a little confused, i had a CAI before stage 2 install, it gave me a few extra hp up top. but the stage 2 power gains were far more! get ready to get flamed for that comment!
Old Sep 13, 2007 | 04:00 PM
  #84
OniMirage's Avatar
so take off the intake and see how stage 2 feels. There is easily a difference and not just in sound. It would seem everyone is forgetting how effeciency causes differences in the way a car can perform. Throttle response, engine response, supercharger effeciency, intake temps, air filter effeciency, physical restrictions. There are lots of things that can cause the car to not perform as well as it can even though small they add up. Horsepower isn't the end all of performance either. Lets say stage 2 has more horsepower on the very top end of a 7k rpm run. What about 6k rpm? or 5 or 4? What if the car with the intake was easily more effecient and as a result had higher hp and tq throughout the rpm range until 6000 rpm and beyond? Would this mean that the car with the stage 2 had the advantage? The car without stage 2 would be switching gears sooner and would have or be near max boost sooner than the car with stage 2 which is what I experienced when I lost the races
Old Sep 17, 2007 | 03:37 PM
  #85
ARedWhiner's Avatar
thanks for the info
Old Sep 17, 2007 | 05:55 PM
  #86
ifknrock09's Avatar
Originally Posted by silentd
ya im thinking about going with a 2.9 with 60lb injectors and possibly a 50 shot.... the nitrious is what im debating on, and once i learn to tune more thats when the 60's will go on with the 2.9
why go nitrious? why not methanol? its safer and has a very similar effect.
Old Sep 19, 2007 | 04:18 AM
  #87
Nitrous =
Last edited by JKennedy1612; Sep 19, 2007 at 04:18 AM. Reason: Automerged Doublepost
Old Sep 22, 2007 | 02:22 PM
  #88
SSMOKEM's Avatar
Originally Posted by sscobaltscZ06
The I saw he was from Texas...Lotta bullsh** in Texas....
I take a offense to that.... Saw you were from NorCal, "Lotta **** in NorCal"
Old Sep 22, 2007 | 03:04 PM
  #89
M-Dub's Avatar
JKEN how are you liking the 2.9" I haven't had one clutch issue. I just got my exhaust done now... and you know you loose a psi or 2 of boost, but it's worth it! WOW
Old Sep 22, 2007 | 05:18 PM
  #90
hg_5's Avatar
Texas ftmw LOL
Old Sep 22, 2007 | 05:44 PM
  #91
It's nice...loose a pound of two of boost? What are you talkin' about?
Old Sep 22, 2007 | 05:46 PM
  #92
hg_5's Avatar
The better flow your engine has the less boost u make. So now that he upgraded his exhaust he is making more power on less boost.
Old Sep 23, 2007 | 04:20 AM
  #93
Uhhh...can someone confirm this? Or at least explain it more in detail because that doesn't make much sense to me
Old Sep 23, 2007 | 10:15 AM
  #94
InfinityzeN's Avatar
Damn it, someone needs to find all my explanations and make a sticky with them.
Ok, your supercharger is a pump, your manifold is an air tank, and your engine/exhaust is a release valve. Since the supercharger is belt driven, it will always flow roughly the same CFM of air per engine rpm. This air isn't compressed until it is inside of your manifold, so your boost gauge is actually showing you manifold pressure.
Ok, so all this air is getting forced into your engine, but your engine can only use so much volume of it at once. This is determined by head flow, cams timing, valve size, engine bore and stroke, exhaust, etc. So even though your engine is moving the most volume at once it can, more air then it is using is getting pushed into the manifold by the supercharger. More and more air pushed in builds up pressure. As the pressure goes up there is more "Air" per volume (your Boost, or air pressure above ambiant/14.6psi), so even though your engine doesn't move a higher volume, it is moving more air. Eventually the pressure will reach a point were the engines usage equals about the same amount as the supercharger is pushing into it. That is where your boost will mostly flatten out.
Even after you hit the point where engine usage and supercharger intake are about the same (about 12~13psi with stage 2), your boost will still continue to climb as conditions change and your engines ability to use air worsen. Those changes would be increasing heat (which makes the air expand and increases psi), running out of cam, exhaust restrictions as flow needs raise, etc. Eventually, you'll hit redline at your peak boost (about 15psi for stage 2).
Now thinking of it as an air pump (supercharger), air tank (manifold), and release valve (engine/exhaust), anything you do to increase engine flow will have the same effect as a larger release valve on the air tank. In other words, even though your air pump is still flowing the same amount of air, the tank ends up having a lower pressure that it balances at.
Lower pressure is good since it gives less heat, causes less stress, and allows the supercharger to work closer to its peak efficacy range. All in all a good thing.
So to make it simple, with a positive displacement supercharger, you want the lowest possible psi for a given air flow rate to make the most power.
Old Sep 23, 2007 | 01:00 PM
  #95
OniMirage's Avatar
LOL that sounds like the scientists explaination.
Old Sep 23, 2007 | 01:44 PM
  #96
Finally someone who knows what they're talking about
Old Sep 23, 2007 | 01:49 PM
  #97
Hell man, you would think I would just start copy/pasting that instead of typing it out every time I gotta explain it. But then I'm too lazy to dig around and find the last time I explained it, so I just type it out again.
Old Sep 24, 2007 | 03:59 AM
  #98
hg_5's Avatar
Thank you for making my dummy explanation in to a better sounding one. I know as much as I read in these forums.
Old Oct 4, 2007 | 06:38 PM
  #99
ARedWhiner's Avatar
yah cool thanks
Old Jan 1, 2008 | 03:48 PM
  #100
Bump for those who need help
DarrenGC
Dec 24, 2021 01:55 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
