stage 2 kit, whats included and whats needed.
i just bought a gm stage 1+2 kit and im wondering if there was suppose to be a injector harness included, i though it was. also do i need to change my sparkplugs when i install this kit?
thanks
Justin
thanks
Justin
Why would you go with the GM kit? OTTP and ZZP make better kits for far less money, and you are actually able to customize them. But anywho, you shouldn't need a new harness for 42's and I believe you get new spark plugs to swap out
the only thing you get with GM's stage 2 kit is injectors, pulley, belt, stage 2 blue bolts and the specialty tool you need to install said bolts. You don't need new plugs. It's meant to run with a stock block.
You want my biggest piece of advice if you're really wanting to stick with that crap? Ignore going to the dealer for the reflash and find someone in your area that can give you a decent tune with HPTuners. The stage 2 reflash runs close to 10:1 at WOT, way out of the block's efficiency range.
Sorry guys. Hate on the gm stage kit all you want, its the only thing that's at my reach, and the only place I can get it tuned is gm so I had no other choice, I wasn't about to buy another pcm with the tune already on it. . And my car is still under waranty. I'm sure I'll enjoy it. Thanks to the people who actually helped
