Stage 2 Lean issues
Stage 2 Lean issues
Hello All, I just purchased a ZZP stage 2 kit with the #42 injectors, 2.9" pulley, GM belt and sent out the PCM to be flashed. After 2 days of driving my check engine light came on. PO171, system lean.
Here are my Performance Mods I have had for the past 2 years without any issues and still covered under the GM warranty.
- ZZP stage 3 Heat Exchanger
- Hahn 3" cat back
- Injen intake
I mentioned the Intake as many know the lean code can be tripped by those being on the car. I have had it for two years with no issues.
I know most of the causes but there are to many to test for in short time. I am looking for someone who had the same issue or same experience with ZZP and can point me in the right direction.
I am not having idle issues but i do get the slight bucking in second gear that has been noted as normal with our electric throttle control system.
- Hahn 3" cat back
- Injen intake
