stage 2 recently, CEL trippedd
Old Nov 24, 2007 | 06:19 PM
Sachemhockey44's Avatar
i recently got my stage 2 put on maybe 2 weeks ago or so , and my CEL went on today and i got it scanned and the guy said bank 1 is running too lean...also when i was at the dealership the girl told me the CEL came on while he was test driving it, then 5 minutes later he came back and gave me my car, with no CEL on i wonder if he just erased it....please help is this bad??
Old Nov 24, 2007 | 06:27 PM
Herndon_High_SS's Avatar
What's your car's redline set at?
7k.... its gotten alot colder here recently too if that means ne thing
Old Nov 24, 2007 | 06:28 PM
hmmm. well at least the reflashed it. Maybe someone that knows more will chime in.
Old Nov 24, 2007 | 06:30 PM
yea is running lean really bad for my car i dont wanna mess it up
Old Nov 24, 2007 | 06:52 PM
JimHarr18's Avatar
lean is less gas. rich is more gas. if its too lean, your cylinders not getting enough gas, which potentially/will blow your engine, which is kind a bad. i'd get it looked at if i were you. could be something wrong with the fuel injector in the 1st cylinder.
Old Nov 24, 2007 | 08:02 PM
oh **** ok ill get that checked out asap wow now im really nervous
Old Nov 24, 2007 | 11:57 PM
BoostingSS's Avatar
Dont get worked up, that code can be triped by alot of things i got the code 2 days after my stage 2 and it turned out to be the clamp at the throttle body that holds the intake to it was loose. Check for intake leaks ,I even read that the dip stick not being seated properly can cause this code.
Visually and physically inspect the following items:
• The vacuum hoses for splits, kinks, and proper connections
Inspect for the following conditions:
• The HO2S for proper installation
• Missing, loose, or leaking exhaust components
• Vacuum leaks at the intake manifold, throttle body, and injector O-rings
• The air induction system and air intake ducts for leaks
• The crankcase ventilation system for leaks
• The evaporative canister purge pipes for obstructions or plugging
Old Nov 25, 2007 | 12:00 AM
devon9832's Avatar
^^^^^^What he said.... basically, i had the same problem and it comes on ever so often, its probably a kink or a hole in ur connections. nothing really too serious to take to a dealer and have them rape you with no lube for 100 bucks and say its fine!!!!!
turbochargedss2012
Sep 20, 2023 12:17 PM
Tupp
Sep 30, 2015 08:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
DocSvensk
Sep 27, 2015 02:24 PM
roth
Sep 26, 2015 12:16 PM
