Stage 2 Upgrade 3.1" or 3.0"?
Old 06-15-2013, 01:50 AM
mklein6590's Avatar
I know there are a lot of threads about the stage kits but I have yet to get a definite answer on this. I have a stock cobalt aside from a stage 2 clutch and a zzp 3" CAI, is it safe to run a 3.0" pulley with 42# injectors and NO cooling mods? Or should I just go with the 3.1"? I plan on replacing my exhaust soon as well but I don't want to put money into cooling mods right now. I just don't need anything breaking. If any of you guys could help me Id appreciate it.
Old 06-15-2013, 02:00 AM
redcobalt07's Avatar
do you wanna put money into fixing a blown motor?
Old 06-15-2013, 02:02 AM
mklein6590's Avatar
ha so youre saying i should go with the 3.1?
Old 06-15-2013, 11:14 AM
Gelladuga69's Avatar
You could really go as far as 2.8 and 60's with no supporting mods, but you're IAT2's will be pretty high after 1 pull.
Old 06-15-2013, 12:49 PM
blueLNFftw's Avatar
Its fine to run a 3.0 with no extra cooling mods.
However, it is not fine or safe to toss in a 3.0 and injectors and run it.
There is this thing, its called tuning for it.....
If your stock then stage up the right way.
Option B, FMHE, Dual pass, 3.0 or 2.9, 42's, wideband, and a custom tune.
Old 06-15-2013, 01:22 PM
mrbelvedere's Avatar
well hello mr missinformation
COOLING MODS ARE FOR RECOVEREY
Option B, FMHE, Dual pass,.
yes tune is needed COOLING MODS ARE NOT The only one's worth a dam is the option b and a extra h.e. or a griffen or similar capacity is where you get better temp control
Old 06-15-2013, 01:25 PM
SylverSS/SC's Avatar
I ran my 2.9 on gm stage 2 for a year before I put my option b, h/e and dual pass on. Just don't do pull after pull after pull and you should be fine
Old 06-15-2013, 03:53 PM
mklein6590's Avatar
Alright I am leaning towards the 3.0 now and just not gonna beat on it too bad until I get the endplate and option b. My question now is 42# injectors okay to run on that?
Old 06-15-2013, 04:56 PM
Yes, 42# will handle 3.0 just fine. 2.9 and lower you're gonna wanna upgrade.
Old 06-15-2013, 05:48 PM
mklein6590's Avatar
Alright thanks a lot you guys
Old 06-15-2013, 08:40 PM
blueLNFftw's Avatar
I was told by a reputable tuner on here that 42's would be fine for up to a 2.8"
Old 06-16-2013, 08:13 AM
Possibly since GMS3 is 2.9? ZZP says 42# max out at 3.1.. Better safe than sorry, I guess.
Old 06-16-2013, 09:30 AM
I maxed out 42s at around 5500 rpms on a 2.9 back in the day.
Old 06-16-2013, 10:19 AM
TStone's Avatar
THIS!!
When will people learn!?
Zharrington_2010LNF
02-08-2016 01:43 PM
HEATON
10-16-2015 07:21 PM
dieGone
10-01-2015 06:27 PM
OPCrer
09-27-2015 08:11 PM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: Stage 2 Upgrade 3.1" or 3.0"?
