stage 3 ss sc
Old Sep 11, 2013 | 09:37 PM
tylerjohnson's Avatar
stage 3 ss sc
I want a zzp stage 3 kit, I have a bone stock 06 lsj. Other mods open to, would it be fine to start with a kit and still have stock exhaust and no cai as long as I check if my inter cooler works?
Old Sep 11, 2013 | 09:40 PM
mahfouzman's Avatar
Yes make sure you check that pump, your power will hurt if it doesn't work. The stage 3 kit comes with the intercooler so you won't have to worry about that, and as far as exhaust goes I say you should at least upgrade to a less restrictive header, if not downpipe and catback as well. CAI isn't going to make a huge difference I don't think, just do the airbox mod and you'll be fine.
Old Sep 11, 2013 | 09:44 PM
I should have a stock intercooler and thee kit has an added heat exchanger as an option (don't exactly know the full purpose) and I will do the mods eventually I'm just wondering if without them will anything get wrecked? Also what are you referring to as the air box mod, an intercooler I'm assuming?
Old Sep 11, 2013 | 09:52 PM
iToastie's Avatar
You'll be fine with everything that comes with the stage 3 kit. Just put it all on at once, don't do half one day, drive around, and then do the other.
The stage 3 comes with a front mount heat exchanger, it works with the stock intercooler, but it's literally mounted in front.
Old Sep 11, 2013 | 09:58 PM
Thank you itoastie I appreciate it a lot man! Any other advice on anything to a new and learning guy like myself
Old Sep 11, 2013 | 10:09 PM
the extra heat exchanger helps because a) it adds more fluid to the system and b) its in front of the ac condenser, stock heat exhanger and radiator so it doesnt get heated up from them.
all good for keeping your intake temps low. if the temps are too high (i think 120+ iat2) the computer starts pulling timing which means power
Old Sep 11, 2013 | 10:13 PM
iToastie's Avatar
Intake will make your supercharger scream, not much else until it's tuned for it
mahfouzman's Avatar
No the airbox mod is when you take your stock airbox, remove the stock filter, put an aftermarket filter, and don't replace the bottom cover, allowing more air to enter your engine. Of course I would recommend getting a water sleeve for the filter just in case, I have one on mine and have never had problems in the rain. No you won't wreck anything, you'll just not make as much power as you should be making.
Old Sep 11, 2013 | 10:14 PM
mahfouzman's Avatar
Yeah Toastie makes a good point, make sure you include in the notes for your order that you have the airbox mod if you decide to do it and ZZP will tune accordingly.
Old Sep 11, 2013 | 10:19 PM
airbox mod will make the power but if you want to hear the blower scream get a zzp intake
Old Sep 11, 2013 | 10:27 PM
woowoo16's Avatar
Just installed my stage 3 with 3.0 pulley on 91 octane
Zzp intake, catback and catless downpipe
Currently on the can tune to commute to the gym until my aeroforce and wideband come in then I'll get it tuned
I've owned the car stock for 3 years, I'm surprised it took me this long to buy this, it's seriously wakes up the car.
I'll spin 1st , sometimes spin a little second. Before it wouldn't spin first from a roll. ( I have rotated mounts and decent tires)
Best investment I made in the car by far
Old Sep 11, 2013 | 10:37 PM
Bass_Waves's Avatar
slap a 2.8 on that puppy and let it burn!
Old Sep 11, 2013 | 10:46 PM
Hell yeah!!! thanks guys tons of help much appreciated!!!!
Old Sep 11, 2013 | 10:51 PM
iToastie's Avatar
Just go through ZZP's site and buy one of everything... you'll be good
Old Sep 12, 2013 | 07:38 AM
Staged07SS's Avatar
Administrator
Administrator
Higher than that. More around 140+.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
