Sti Mod
Sti Mod
I have a problem tonight I was driving to go out to eat and I accelerated up to around 40 45 you know normal light acceleration and about a half mile down the road i heard a pop and my check engine light started flashing and the car sounded funny so i pull over and sure enough the car sounds like a sti or that im cammed no dipstick came out but i took the oil cap off and there is air coming through there and some smoke I couldnt see the color because it was pitch black out but there was air definatly coming out of the oil cap and it seemed like somewhere around the top of the supercharger. So i left it in the parking lot and Im getting it towed to my house tommarrow so I can take a better look at it. I was just wondering what you guys think it might be. and the past few weeks there has been a ticking noise that does not go away when you rev the engine so I just assumed that it was the injectors. anyway i have a 07 ss/sc with stage 2 and a 2.9 pulley with full exhaust and a dual pass with a C.A. heat exchanger. So if you guys can let me know what you think it might be I would appreciate it and I will update in the afternoon tommarrow with some more info. Thanks for your help.
who did your tune? what are (were) your Iat2s at WOT? What is (was) your A/F ratio at WOT? do you have an interceptor? did you get any knock? all important questions
its stage 2 tune on a 2.9 when i go WOT in 3rd my a/f are around 10.8-11 my Iat2 dont go about 130 and im pretty sure i wasnt getting any knock i was just driving normaly when this happened and i scanned it and the code was a misfire code if that means anything
it was a misfire code i know that but i will get the exact code tommarrow because i left the car where it was at and im getting it towed home what should i look for when i pull the plugs
mine was misfiring on 1 and 3, i changed the plugs, ran ok till i put 60lb injectors in, havent had it tuned yet, it started and ran for a minute, then ran like ****, now it wont start at all......
