Sti Mod
Old Apr 5, 2008 | 01:34 AM
  #51
Raven SS's Avatar
Originally Posted by ssmokin
yeah but hes not the guy with the sti mod
i know....hes the one everyone highjacked the thread on letting him know hes an idiot..i was just saying maybe hes ******* with u guys
Old Apr 5, 2008 | 01:35 AM
  #52
ssmokin's Avatar
i certainly hope so
Old Apr 5, 2008 | 01:39 AM
  #53
USMCFieldMP's Avatar
Rattlesnake Race Shop
Originally Posted by memphisr24
What compression ratio?
Stock 9.5:1 Pistons.
Originally Posted by italstalnprd86
um i didnt realize you needed one, i assumed that they would just not work to the maximum capacity, but more less mimic the 42.5's, another member i talked to said his did the same thing till he had it tuned, i emailed intense 3 days ago, but they didnt get back to me, so im not impressed with their customer service by anymeans
Haha... there was a guy that I used to work with that graduated with a degree in High Performance Motorsports... he tried telling me that if I put the 60's in... they would run just like the 42's... just lower IDC's. Haha, I called him an idiot. Good thing I didn't listen to him.
And don't ever buy from Intense again. That's a till that all the GTP owners have given me.
i have an ss sc....... and untuned 60 lb
Pull your spark plugs out.. and leave them out. Disconnect your Fuel Pump's Fuse... then crank the car over like 5 times... or some ****. That should help get some of that extra fuel out of there... and put your 42# injectors back in. Put the 60's in when its time to tune.
Old Apr 5, 2008 | 01:41 AM
  #54
italstalnprd86's Avatar
thank you, to clarify, i do not have a 2.4, i have an ss/sc with stage one, and id put the 42's back in accept i sold them...... but thank you for telling me how to get the gas out
Old Apr 5, 2008 | 02:31 AM
  #55
crt013189's Avatar
Stop the treadjacking here start your own thread im trying to see what everyone is saying about my situation and i cant because your jacking my thread.
back on topic
So basically you guys are saing that i should plan for the worst but do you still think i might have some hope as to it being something little and stupid. or am i completly screwed.
Old Apr 5, 2008 | 02:32 AM
  #56
Raven SS's Avatar
50/50 all u can do is all the tests to make sure
Old Apr 5, 2008 | 02:35 AM
  #57
crt013189's Avatar
so compression and a leak down test and both of those will tell me whats going on with the motor.
  #58
Super_SS's Avatar
dont wanna jinx my self,but i got the exact same setup but with a 2.8 and so far knock on wood,its still goin..dont go past 4k cuz of new clutch
Old Apr 5, 2008 | 02:38 AM
  #59
http://videos.streetfire.net/video/T...ded_106346.htm
Watch this, and tell us what you think. Does yours sound like that?
Old Apr 5, 2008 | 02:39 AM
  #60
crt013189's Avatar
the funny thing was that this happened while driving normal not racing or anything just a typical drive to go get some dinner thats why im kinda at a loss as of why this happened
Old Apr 5, 2008 | 02:40 AM
  #61
Super_SS's Avatar
maybe ur idc was goin crazy for so long,that it just took a ****
Old Apr 5, 2008 | 02:44 AM
  #62
crt013189's Avatar
kinda but not really mine has more of that sound near the engine area but louded kinda it was hard to hear on the video but im not sure i didnt want to run it for a while because im not sure what had happened and i didnt want to make it worse
but i cant see the IDC going crazy during cruising you know
Old Apr 5, 2008 | 02:45 AM
  #63
Blackout06LS's Avatar
Originally Posted by 06_SS_S/C
can you use the enter key next time? its hard to read that when your are drunk
x2
I would key in my advice, but I couldn't really read it as I'm buzzed like hell.
So redo. But I assumeyou've gotten your answer.
Old Apr 5, 2008 | 03:01 AM
  #64
crt013189's Avatar
well im going to sleep now so i will update with more info tommarrow afternoon
Old Apr 5, 2008 | 03:03 AM
  #65
Good luck buddy... like i said... if it is the worst outcome... I will sell you those Pistons at a good price.
Old Apr 5, 2008 | 03:05 AM
  #66
crt013189's Avatar
ok i will let you know can u at least hold them till this weekend so i can find out whats going on with the car if you can i would appreciate it and thanks for the help guys
Old Apr 5, 2008 | 03:07 AM
  #67
There isn't a for sale thread for them. I have them laying around for the one day that I decide to get crazy. SOUNDS like you need them more than me... so I am willing to part with them for that reason.
Old Apr 5, 2008 | 08:20 AM
  #68
*TRIX*'s Avatar
Same thing happend to mine. Gm gave me acompletely new motor. It was shot
Same thing happend to mine. Gm gave me acompletely new motor. It was shot. But I also ran 42lb injectors on a 2.7 pulley with no cooling mods whatsoever....super lean!
Old Apr 5, 2008 | 08:31 AM
  #69
I had the same thing happened to me once with normal driving, same exact thing as your describing, smoke/steam looking coming from under the hood, wrx sound, turned it off and turned it on, no cel, and it ran fine. that was 4 months ago. no problems since. maybe youll be lucky like me. Goodluck tho. interested to hear what the outcome is....
Old Apr 5, 2008 | 08:36 AM
  #70
SSdan's Avatar
Thought I did this last night, misfire at 6500
Ended up fine.
Old Apr 5, 2008 | 08:49 AM
  #71
crt013189's Avatar
did you let the car sit for a while before you started it again because i turned it off and started it like 10 min later and the problem was still there ill get more info today because im getting it towed to my house im gunna do a leakdown and compression test.
Old Apr 5, 2008 | 08:50 AM
  #72
R&C_rallySS's Avatar
This is a interesting thread. If it is a piston, it will be the first one I heard of on a 2.9 pulley. As far as warnity goes, put your stock intake/box back in, remove the H/E, and remove the 2.9 pulley. They can't void your warinty then. Trust me, it could be alot of work but well worth it if they cover the engine work assuming it is a piston. Either way, good luck to you.
Old Apr 5, 2008 | 04:28 PM
  #73
crt013189's Avatar
turns out it was the spark plug in the #3 cylinder head it was stripped out when i removed the boot the spark plug came up with it i can just drop the plug in there it goes all the way down without even screwing it in so im screwed now do you guys think the dealer will cover it under warrenty or not
Old Apr 5, 2008 | 05:03 PM
  #74
I gave it about 2 mins or so as I was looking in the engine bay and under the car for any fluids coming out. started up and was fine.
Old Apr 5, 2008 | 05:21 PM
  #75
tru2nrtt777's Avatar
Is it an ACDelco plug or aftermarket? If it is ACD you should be covered as a defect in workmanship. If not, you are screwed there buddy.
