Sti Mod
turns out it was the spark plug in the #3 cylinder head it was stripped out when i removed the boot the spark plug came up with it i can just drop the plug in there it goes all the way down without even screwing it in so im screwed now do you guys think the dealer will cover it under warrenty or not
if you installed the plug's they wont cover a damn thing.. but since in your mod's list there is no aftermarket plug's i would assume that you are on the factory ones.. and if you are and they are stripped then they HAVE TO COVER IT... **** even if u have different plug's and it was the dealer who put em im then it's there fault.
weeeeellllllllllllllllllllll
you won't blow a plug out due to detonation. it will eat the ground strap. someone over torqued the plugs. it doesn't take much. maybe 10 ft lbs if that. and thats hand tight
Highgross89
20
Sep 11, 2015 03:24 PM
