Stock Cobalt SS/SC injectors ...
Don't forget that the stock LSJ fuel pressure runs somewhere between 50 and 62 PSI (highest numbers at WOT). For those who want to make some calculations, since this car is a forced induction one, you MUST use the differential pressure (I mean if there is 62 PSI in the fuel rail at WOT with the stock supercharger pulley running at 12 PSI, the differential pressure through the injectors (bone stock) to be used for calculation is 62-12 = 50 PSI).
Some notice that the fuel rail pressure can increase up to 70 PSI when running a 2.9" pulley, giving a differential pressure of 55 PSI.
The results gives 380 cc / min (36,2 lb/hr) @ 43,5 PSI, as I saw on the flow bench.
EDITED ENTIRE POST : Hi ! You can be sure that I'm very glad to get some help from you guys.
About the constant fuel pressure of 66 PSI, it has been achieved with a smaller than stock supercharger pulley don't it ???
WhineSSbaby
Sep 1, 2020 12:39 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
