Stock internals!!!!
dont know exactly but its been posted alot. plenty of people above 400whp on stock internals, its all in the tune, and supporting mods. also clutches are usually based on tq, so whne you figure your tq out we can let you know which clutch to get.
300 is safe ( ish ). Honestly, pushing the engine past 300 whp on stock internals is asking for trouble.
you can make higher numbers "safely" on a turbo setup than an upgraded SC. If you want to blow your **** up, try running an undersized pulley on the stock SC.
theyre time bombs. Hahn recommends keeping it below 350 without forged internals on their turbo setups for a reason.
350+ to the tire.
300+ ft lbs t the tire.
has been over 300whp for roughly 50k miles.
jussayin.
there are plenty of people who have blown their **** up, and plenty who havent. Is it worth the risk to me? Hell no.
if youre going to do an entire build, you should always start with the engine and work your way up. This is just good practice.
they're doing it wrong .. stock internals can easily handle 350+ if tuned correctly with the right mods
why crack open the motor when you don't need to ? these damn things can handle 400 whp WHEN TUNED RIGHT is the key
