Stock LSJ E47 tune
Old Apr 16, 2014 | 11:59 AM
Olybaltss's Avatar
Stock LSJ E47 tune
What would I need on my end if I was to try finding somebody that can tune me for E47? If i'm meeting up with somebody that has HPT, I only need my car at that point, correct?
And I looked through the forums, but didn't see any consistency; do we have any real #'s on increases with this tune/mod?
Old Apr 16, 2014 | 12:02 PM
user 72239's Avatar
Why would you do E47 with an LSJ? Swap in the correct injectors and do Full E85.
Old Apr 16, 2014 | 12:10 PM
yellowsupercharged06's Avatar
yea tune for full E85
E47 is mixing and needs to be exact which E never is.
get some 80's too
Old Apr 16, 2014 | 02:16 PM
mrbelvedere's Avatar
there is noithing wrong with doing an e47 mix and it dose not have to be an exact mix every time just close and the ss/tc guys do it a lot op go do it and enjoy
Old Apr 16, 2014 | 02:25 PM
Olybaltss's Avatar
I had started out thinking E85, but it seems a large advantage in E is being able to up your timing; as I'm near stock (air-box mod), I wasn't sure if I would get the same advantage.
A few posts claim that there is a 20-30% loss in MPG when you're running E, does that seem realistic? and worth the gains when stock?
Thanks, by the way.
****, I knew about the injectors, because of the seals and needing higher flow rate right? Just forgot to list them.
It's on. thanks boss.
Old Apr 16, 2014 | 02:29 PM
for the time/energy to mix that crap ... just suck up the shitty mpg and fill an go
im my opinion it takes a pretty skilled tuner to dial something in that will be good for anything from E70-E85 ... now you mix the additional mixing into the equation it just gets fuzzier
just my $0.02 ... just go full E85
Old Apr 16, 2014 | 02:34 PM
Olybaltss's Avatar
I have no problem going with E85, just didn't think I had enough supporting mods to make it really worthwhile. thanks for the advice guys.
Old Apr 16, 2014 | 02:36 PM
user 72239's Avatar
Thanks, by the way.
Some state that E47 will give you the same power gains as full E85, but the SS/TC guys have to run E47 because our fueling wont keep up with the demand of full E85.
However, If I still owned my LSJ I would just go full E85 since mixing just seems like a hassle. 80# injectors and a solid tune and you are g2g.
This is just my opinion.
Old Apr 16, 2014 | 03:08 PM
Olybaltss's Avatar
I'm pretty sure this is the way I'll go. then all I need is somebody that has HPT for an LSJ that would be willing to work w/me on tuning, correct?
Old Apr 16, 2014 | 03:10 PM
user 72239's Avatar
80# injectors, and someone who has HPT and a knowledgeable LSJ tuner
hhrfreek
Jun 4, 2016 11:25 PM
Hugger1975
Oct 15, 2015 03:28 PM
vjoel2011
Oct 2, 2015 12:11 PM
camaromanss1992
Oct 1, 2015 10:51 PM
Sep 15, 2015 04:38 PM
