stripped screw
Old 01-27-2011, 05:11 PM
sexy_ss's Avatar
stripped screw
Hey guys I need some help, i just bought a cobalt ss/sc 06...went to change the plugs and within 2 turns the screw was stripped on top of the engine cover...how do i get it out?
Old 01-27-2011, 05:14 PM
O9cobaltSS's Avatar
exactly how stripped is it?
Old 01-27-2011, 05:16 PM
scottydoh's Avatar
this^ A picture might help too...
Old 01-27-2011, 05:27 PM
insylem's Avatar
Few Options:
Use an EZ-Out
Drill it out
Get some really tough Glue or JB weld, and get a Torx bit you don't want to keep, and glue the two together.
Old 01-27-2011, 05:31 PM
sexy_ss's Avatar
What's a ez-out...and its prey bad the person before me must have tried bc its bad
Black SS/SC 06's Avatar
Those spark plug cover screws can be a pain. I replaced mine with hex style bolts because they strip too easy.
Old 01-27-2011, 05:32 PM
It's a bit designed to pull out stripped screws.
Old 01-27-2011, 05:33 PM
Jeffs 06SS 2.4's Avatar
Where is the pic? If the hole is stripped, you could maybe pry up with a flat head screwdriver while you turn it. If the head is stripped. They sell a set of socket looking things that will grip on any round surface and screw it out. I have a set and they work really good. They have a cutting spiral in them thats grabs the bolt or whatever it is if it has a head on it.
Old 01-27-2011, 05:35 PM
kxrida2000's Avatar
i did the same thing and yes an ez out would be your best bet
Old 01-27-2011, 05:54 PM
sexy_ss's Avatar
Where can I get a ez out...or them sockets that grip anything lol
Old 01-27-2011, 05:56 PM
scottydoh's Avatar
just use a dremel to cut a slot in the head and use a flathead screwdriver or grab the head with vicegrips
Old 01-27-2011, 05:58 PM
PsychoCam's Avatar
ya i say get a set of ex-outs and use a small drill bit. make a hole in the screw and use the ez out to grab inside the hole and turn the ez-out like u would be tightening it. it will grab the inside of the hole and back the stripped screw out
Old 01-27-2011, 06:01 PM
insylem's Avatar
I think those socket grip things that the OP mentioned are the best way. Possiblly BETTER then an EZ Out. I had forgotten about those. I've seen them at hardware stores...
Old 01-27-2011, 06:05 PM
sexy_ss's Avatar
Any idea what the socket things are called?
Old 01-27-2011, 06:10 PM
reefone's Avatar
no idea what the socket thing r called but i got a set from sears.
Old 01-27-2011, 06:16 PM
sexy_ss's Avatar
I'll have to swing by then...ill let you guys know how I make out
Old 01-27-2011, 06:28 PM
DebadgedBALT77's Avatar
i thought EZ outs were the easiest things to use. Drill. and "screw" out
Old 01-27-2011, 06:33 PM
sexy_ss's Avatar
How exactly do you do it, I've never done it
Old 01-27-2011, 06:38 PM
SSSnoop's Avatar
With the ez outs, drill the center of the screw - using a smaller bit than the screw size (of course - since you can easily drill the screw head off!). Take the easy out, and turn it by hand into the drill hole - using pliers or wrench to help in the torque department, and it should pop the screw right out. Don't chuck the ez out in a drill - you'll either spin it too fast or break it.
I've done the dremel-slot thing as well, and that works great.
Old 01-27-2011, 06:45 PM
sexy_ss's Avatar
Okay thank you..ill see if sears has those socket things, if not ill do what u said. I already tried vice grips but the head is too small it won't grip it.
Old 01-28-2011, 07:01 PM
stonny9's Avatar
but also hold the screwdriver pushing down on it and at the same time hit the end of the screwdriver with a hammer and turn it at the same time. should come right out that way
How to Guide
57
10-15-2015 11:56 AM
importkiller
09-30-2015 07:18 PM
brickloaf
09-21-2015 02:17 PM
XStylus
Forced Induction
09-16-2015 06:19 AM
Getaway_Driver
09-08-2015 09:41 AM
Quick Reply: stripped screw
