Struts and mounts cobalt ss/sc 07
Old Mar 11, 2012 | 05:55 PM
rms7design's Avatar
Hello,
I browsed a lot of threads but did not find all the info I need.
Went to the dealership and was told that my left front strut is leaking. Was told that I need to replace struts and mounts.
Was also told that there is a quick kit instead of the full kit (not sure what they meant - is it a special strut with mount ??).
Anyhow, I found on ott a kit with front, rear struts and shocks with springs. I am thinking about changing the whole thing instead of just the front (not sure it is good to change the front and not the rear) but I did not find anything about suspension mounts.
So, what would your advice be? change only the front struts and mounts? change front and rear and shocks? Where should i get mounts? Ever heard of the quick kit?
Thanks for your answer
Cobalt ss/sc 07 (I read that using the ss/tc strut/shocks is ok)
Old Mar 11, 2012 | 06:07 PM
K-Train04RL's Avatar
Depending on how many miles I would change the mount. They r known to make noise. Personally if I was over 60k I would do them. And the quick strut is a strut spring and mount kit already assembled. Which means no swapping springs and less labour. The mounts from ced are like 50 bucks each.
Old Mar 12, 2012 | 03:54 PM
rms7design's Avatar
strut spring kit
this for the info,
where can I find such assembled kit?
this
Old Mar 12, 2012 | 04:19 PM
mrbelvedere's Avatar
your best bet is to call c.e.d 1 877 441 5150 ask for tom and get the lnf struts and bearing asembly and depending on the miles replace the rear shocks with the lnf shocks they are an updated version of the lsj stuff
Old Mar 12, 2012 | 05:21 PM
BCM's Avatar
BCM
Struts/shocks
Cobalt FE5 Struts and Shock Pkg FE5-S
Strut mounts if you want to replace them.
Cobalt Upper Strut Mount 88964326
Old Mar 12, 2012 | 08:42 PM
rms7design's Avatar
struts and mounts
thanks for the info.
BCM,
for the mounts, should I get the bearing as well? at rock auto they have this
RAYBESTOS Part # 5201478 Professional Grade
Contains Bearing; Front for about 1/3 of the price of the ones u mentioned.
Am I missing something? and yes, I will replace the rear shocks as well but keep my oem springs (car has 100k).
this
Old Mar 15, 2012 | 08:16 AM
05vue-redline-06ion's Avatar
I did all my research and put TC shocks struts and new MOOG mounts for around $350...i think..... Cheaper the CED all day long.....RA.com
Old Mar 16, 2012 | 02:03 AM
rms7design's Avatar
struts and all
I ended up ordering the fe5 pckg front/back and get some TC springs, and new strut mounts and bearing. waiting for 2 of the 3 to arrive and then... putting those on..
WhineSSbaby
Sep 1, 2020 12:39 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
ROADKONE
Sep 9, 2015 02:32 PM
Bluelightning
Sep 8, 2015 05:18 PM
medic710
Sep 6, 2015 08:53 PM
