studder at wot
Old Dec 11, 2010 | 06:51 PM
defo98's Avatar
studder at wot
Recently had the ottp stage 2 kit on... 2.8 pulley, 60's and every once in a while when I got wot i get a studder around 4-4500rpm. Its a quick studder but it can be felt. Im on a canned tune from ottp with a zzp dual pass, header, gutted dp, 2.5 borla exhaust. also my plugs are gapped at .032
Old Dec 11, 2010 | 07:03 PM
ULWizSS's Avatar
Lets take a log when you get a chance and we can take a peak whats going on. I can post the log once we get together again so more experienced tuners can take a look. The tune on this car is directly from OTTP and was just uploaded to his ecu. Nothing else was changed on this tune.
Old Dec 11, 2010 | 07:18 PM
defo98's Avatar
thanks Lars yeah lets do that i'll drive out to you whenever your free
Old Dec 11, 2010 | 09:38 PM
joshcsepegi's Avatar
i have a random studder at wot. it has something to do with the cam position sensor
Old Dec 11, 2010 | 09:39 PM
ItalianJoe1's Avatar
Most LSJ's have a dead spot in the upper rpm range that basically presents as a misfire. It tends to show up as you mod more heavily. Mine used to do it between 5000-5700rpms usually, only one time, felt like it hit a rev limit but then it kept going just fine. Usually showed up in 2nd gear, sometimes in 3rd. Nothing to do about it.
Old Dec 12, 2010 | 08:43 AM
ULWizSS's Avatar
Yeah i remember mine doing it a few times but this was when i was untuned still.
I will post the logs up so people can take a look.
Old Dec 12, 2010 | 02:12 PM
InfraRedline's Avatar
I have had this happen a few times as well on every setup I have ran. Just feels like a quick single violent misfire.
Old Dec 13, 2010 | 01:24 PM
defo98's Avatar
Exactly
Old Dec 13, 2010 | 02:00 PM
Staged07SS's Avatar
Administrator
Administrator
I experienced a similar issue (same rpm & gear). Found out it was spark blowout due to flowing more air. I regapped my plugs from 0.035"-0.032" and never had the issue again. Not saying it was the same issue as yours, but it sounded familiar.
Old Dec 13, 2010 | 02:05 PM
Gapping lower helped my car, but I still get it every once in a long while
Old Dec 13, 2010 | 02:19 PM
Chevycobaltss3's Avatar
Bllow bloooooooow bye do what staged said. I gappee mine to. 030 and bam no problems.
Turbo Johnny
Feb 21, 2019 09:41 AM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
007Buff
Jun 11, 2017 03:04 PM
007Buff
Sep 22, 2015 09:48 AM
TylerJHowell
Sep 21, 2015 06:47 PM
