Stupid Coolant Question
Ok I know Im going to sound like a idiot but here it goes. I just replaced my radiator and stock heat exchanger last night since I hit a semi tire on the interstate. (waiting for my a/c condenser to come in before I add the cx racing H/E). First question the radiator and h/e are to separate cooling systems right. Im guessing the filler in front of the supercharger is for the h/e and the other is radiator? Also what kind of coolant should I put in. Will it be all coolant or mixture. Any help will be great thanks.
Use a 50/50 Dexcool mix.
There is a special fill procedure for the SS'. Remove the upper rad hose and pour it in thru there until its full. Then start and idle the car at 2500rpm for a few mins. Top it off and repeat. Then top off the overflow tank.
Yes, they are 2 separate systems also.
