Swapped Oil Pans
Swapped Oil Pans
Ok so I swapped my lsj pan for a 2.2/2.4 pan only question is that the dipstick i can just pull it out with almost no effort while the old one didn't come out as easily. You guys that have swapped, did you put anything on the dipstick at all where it pushes into the pan? Or will it be ok lol.
I haven't switched pans just had a bung welded into my stock pan but i've never had any issues with the dipstick. I made a bracket underneath my intake manifold that holds a catch can and also holds my dipstick in place so there is no chance of it popping out or coming loose or anything.
was yours kinda easy to pull in and out of the pan after you had it out? i'll prob just use some uv rated zip ties and tie it to something down there with the bracket thats on it haha
this is what i did. mine pulled out easy and zipped tied it to a bracket i made and havent had a problem with it leaking or sliding out.
ThoR294
Oct 4, 2015 08:44 PM
