Switching to E85
Old May 24, 2011 | 08:09 PM
BLue NoTe's Avatar
Switching to E85
So after a year of envying you guys with your E85 the Shell station right by my house just installed a pump and I couldnt be more excited. Since Im new to the corn fuel I wanted to know if I was good to go now for a mixture. My buddy's wrx has a Cobb tune and he's gradually weening onto the stuff. I have a custom tune, stock pump and 60's, what could I safely do right now with no other mods?
Old May 24, 2011 | 08:16 PM
Chevycobaltss3's Avatar
The smallest pulley I've been able to tune for was a 2.8 with ids of 98% if u have no pulley u r fine...
Old May 24, 2011 | 08:18 PM
BLue NoTe's Avatar
Ive got the 2.8, should have mentioned that
Old May 24, 2011 | 09:43 PM
Depends on Ure afr at wot and it depends on aggressiveness on tune.
Old May 24, 2011 | 09:44 PM
conerboner's Avatar
Might want to get 80s before you get crazy!
Old May 24, 2011 | 09:49 PM
Lol. If you don't want to get near are max then yes get 80s..
Old May 24, 2011 | 10:14 PM
BLue NoTe's Avatar
Figured that'd be the deal, but Do you think I could do a 20% e85/ 80% v power as it is now? And what part of KY are you in? I might hire you for some tuning
Old May 24, 2011 | 10:16 PM
WSFrazier's Avatar
Instead of buying injectors, get something like a ZZP fuel system, or even OTTP's. Money better spent.
Old May 24, 2011 | 10:20 PM
BLue NoTe's Avatar
Ill probably eventually get both then of course the TVS, just trying to max out the little Heaton before its replaced
Old May 24, 2011 | 10:25 PM
WSFrazier's Avatar
With the fuel system upgrade, you won't need the 80# injectors.
With the TVS you will need both.
Pick your poison.
Old May 24, 2011 | 10:31 PM
ecot3c inside's Avatar
you can't just put e85 in your tank without an e85 tune. You can put a little bit, but what's the point? you still have your gas tune. get 80# injectors or a fuel system like frazier said. Putting e85 in your tank is not "instant power" you NEED to get the spark advance from a new tune to actually benefit, otherwise your not making any power from a mixture in your tank.
Old May 24, 2011 | 10:58 PM
BLue NoTe's Avatar
Im aware of that, but as the first post said the Cobb tune in the WRX can self adjust its maps if slowly introduced to the e85, apparently without any tuning or mods up to a 33% mixture
Old May 25, 2011 | 08:16 AM
Im in the northern part of ky...... The issue with running e.. And driving places. Is you need to verify there's e everywhere your going.
Old May 25, 2011 | 08:49 AM
the wrx is different than the ss. not sure why you mentioned this, it has a cobb tune. your ss will not adjust the maps slowly when introduced to e85.
Old May 25, 2011 | 06:34 PM
BLue NoTe's Avatar
Wondering if I could do the same. The consensus is no
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Hugger1975
Oct 15, 2015 03:28 PM
Builttss
Oct 4, 2015 10:21 AM
Macgyver2484
Sep 2, 2015 05:44 PM
