theory behind option b??
Old Nov 5, 2009 | 05:08 PM
pickin my brother up's Avatar
if the coolant hose is above the coolant fill line on the resovoir then how does the coolant even get to the HE? it seems like it doesnt even work and just sits... any help?
Old Nov 5, 2009 | 05:12 PM
when air is bled from the HE it is replaced with coolant
Old Nov 5, 2009 | 05:14 PM
am i dumb? i have option b, but i still dont get what you mean by that. it just doesnt seem like the coolant can reach the hose thats attached to the HE. should i fill my resovoir more?
Old Nov 5, 2009 | 05:36 PM
Hockeyman's Avatar
the small bleeder hose bleeds air out of the h/e, you should see a bit of coolant trickle out of that hose every once in a while.
Old Nov 5, 2009 | 05:52 PM
ssscs10's Avatar
the coolant hose(the 5/8 line) is NOT supposed to be above the tank. if it is, u installed it in the wrong place. the air line(the 1/4 line) catches the air off the h/e. so the air comes up top and pushes the coolant down through the bottom, thus filling it up.
Old Nov 5, 2009 | 06:27 PM
i shouldnt even be saying this, but i was oblivious to the hose on the bottom of the tank. i thought the air bleeding hose was the only line involved.
Old Nov 5, 2009 | 08:34 PM
HunterKiller89's Avatar
it is not a flow through system like you're probably thinking it is. It is pretty much exclusively to more effectively (and constantly) bleed the system of air.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
