is there a how to for changing the timing chain?
Old Aug 18, 2012 | 01:05 AM
Shogokuma's Avatar
i need some info on changing the guides and the chain and the whole thing, after 2 timing chian tensioner i still get the same problem that diesel noise, anyone know if im missing something here?
Old Aug 18, 2012 | 01:21 AM
mrbelvedere's Avatar
no there isent a how to on that get the build book or a gm service manual and i would say your problem is either a worn out chain and sliders or low oil pressure another item to look at is the chain slider bolt the is behind the plug in the head they are known for backing out and another point to look at is the bolt that holds the main tensioner slider in place is also known to break and or stretch allowing the chain to stay loose
Old Aug 18, 2012 | 01:28 AM
Shogokuma's Avatar
can you specify on the build book i think ill buy it.
how do i know if i have low oil pressur my oil is full i checked it last night
Old Aug 18, 2012 | 09:18 PM
its 300 hp build book it takes you thru a complete rebuild you need to hook up an oil pressure guage to see if the oil pressure is
Old Aug 18, 2012 | 09:21 PM
Tjolley's Avatar
3 letters ARP
problem solved.
i got arp bolts on my door hinges lol
Old Aug 19, 2012 | 07:03 PM
Shogokuma's Avatar
Cobalt SS Supercharged engine noise - YouTube
thats my noise on startup, and sometimes a loud tick
Old Aug 19, 2012 | 10:24 PM
DarkChild's Avatar
Replace the timing chain tensioner. It's a $50 part. There is a bolt in the back of your engine you take out and replace.
Old Aug 20, 2012 | 01:00 AM
Shogokuma's Avatar
already did twice
Old Aug 21, 2012 | 12:16 AM
turbosmart4's Avatar
Did the bolt fix the tick....... Hope it did..... I need to check minde too....
Old Aug 21, 2012 | 04:52 AM
Shogokuma's Avatar
i found a broken bolt on the top chain guide
Old Aug 21, 2012 | 07:54 AM
So u haven't fixed it yet?
Old Aug 21, 2012 | 08:44 AM
Shogokuma's Avatar
its at chevrolet they are fixing it for free ill let you know if its solved but i already know thats the problem the chain is loose cause of that.
Old Aug 21, 2012 | 09:20 AM
But urs is an lsj or lnf? What a relief... Well sorta... Hope mine is the damn bolt
Old Aug 21, 2012 | 11:55 AM
Shogokuma's Avatar
lsj
Old Aug 21, 2012 | 11:56 AM
Shogokuma's Avatar
easy way to check would be to take the colt cover off it takes a torx its right by the pulleu tentionner
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
roth
Sep 26, 2015 12:16 PM
