throwing code P0420
Old Jul 27, 2007 | 07:20 PM
silentd's Avatar
throwing code P0420
im trowing a code for catylst bank 1 low...
i just had my exhaust put on today wiht vibrant Headers/Downpipe and hi-flow cat, also with the corsa touring exhaust
anybody know what i should do?
Old Jul 27, 2007 | 07:26 PM
JCswoosher2's Avatar
let it settle in and get use to it is what i say
Old Jul 27, 2007 | 07:29 PM
CTORANGESC's Avatar
Yeah just give it a while and see what happens. I didnt have that problem when I put my vibrant header in
Old Jul 27, 2007 | 07:35 PM
Area47's Avatar
Rent me! per hour
the 02 sensors is before the cat on that set up now.
you will throw a code with that.
find someone with hpt and credits, they can shut it off for you.
Old Jul 27, 2007 | 07:38 PM
xCobalt05x's Avatar
disconect the ground to your battery for 5 minutes. hook it back up and the engine light will be cleared out and the computer will re learn your afr to a sertain extent.
XM15's Avatar
I have the same code sometimes, but I wouldn't worry too much about it.
Old Jul 27, 2007 | 07:43 PM
Area47's Avatar
Rent me! per hour
um, no.
it has NOTHING to do with afr or fuel or anything.
Catalyst System Efficiency Below Threshold (Bank 1)
thats what code p0420 is.
why is he throwing it?
the rear 02 sensor is infront of the cat now.
this code will not hurt anything, just throws a light. in vibrants design, for some odd reason. they did this. the rear 02 sensor is in front of the cat. this does not work for monitoring the cat.
Old Jul 27, 2007 | 07:49 PM
g5mike's Avatar
what he said.^^^^
Old Jul 27, 2007 | 07:51 PM
silentd's Avatar
hmm this might work out to my advantage then!!
you think i can take out the o2 sensor and put the a/f uego gauge in that bung and then just bung another hole past the cat to monitor the cat with the o2 sensor so it throws no codes?
Old Jul 27, 2007 | 07:53 PM
Area47's Avatar
Rent me! per hour
i wouldn't do that unless you have access to hp tuners to shut the codes off. if you don't shut em off, you will throw more codes, and pretty much make it angry.
Old Jul 27, 2007 | 07:58 PM
silentd's Avatar
well im thinking about getting hptuners to learn to tune. something im really interested in and i have the money to get the kit.
why would it cause more problems exactly? wouldnt the computer be reconizing the o2 sensor then and pick up the right readings?
Old Jul 27, 2007 | 08:02 PM
xCobalt05x's Avatar
Originally Posted by Area47
um, no.
ahhh, i didnt see the vibrant part. sorry. i just know that this worked for me when i did my cam swap with the stage 1 cams. computer relearned the afr and never saw the code again. but this wont work with the stage 2 and 3 cams, need tuning for those
Old Jul 27, 2007 | 08:25 PM
silentd's Avatar
why wouldnt switching them work?
Old Jul 29, 2007 | 07:54 PM
silentd's Avatar
alright i just got under my car and guess what????? the 02 sensor on the vibrant is AFTER the cat and im still throwing a code.....any ideas?
Old Jul 29, 2007 | 09:22 PM
xCobalt05x's Avatar
bank low means that you are running leaner then the car wants you to run. Disconnect the battery for a few min. then hook it back up it will have the code cleared out and the computer will re learn the afr. If its more then the computer can compansate for then you will need to tune it.
Old Jul 30, 2007 | 12:18 AM
silentd's Avatar
well did that and it didnt fix...which sucks...i thought stage 2 ran rich not lean? guess ill have to wait for hptuners to come this week
Old Aug 7, 2007 | 05:12 PM
redhotneon's Avatar
bump for any other ideas or updates
Old Aug 7, 2007 | 07:58 PM
silentd's Avatar
yea i still have the same cel... my brother was throwing the same thing so he got an oil change and it was fine then ???? doesnt make sense to me, also when he was at the dealer they said that they just need a new o2 sensor to fix that...idk if that makes sense either
Old Aug 7, 2007 | 08:17 PM
g5mike's Avatar
i used to get a code for the stage2 cams, but now I don't
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
