TOG header
Old Mar 15, 2006 | 09:48 PM
mrewing65's Avatar
TOG Header
I just bought a new at the dealership. It is ok to use OEM gasket on the lower flange.
Old Mar 15, 2006 | 09:54 PM
mrewing65's Avatar
TOG Header
I really want to know your Dyno numbers. I don't have a Dyno around here so post those numbers!!!!
Old Mar 15, 2006 | 09:58 PM
selfinfliction's Avatar
my first run the tog was a gain of 13whp on a mustang dyno, the second run was a 9.9whp gain. i posted th elower numbers cause i was sure everyone would see atleast that, the 13whp would've been about 15whp gains on a dynojet.
Old Mar 16, 2006 | 08:30 AM
mrewing65's Avatar
Thanks for the update!
Old Mar 16, 2006 | 08:48 AM
3fo893013L's Avatar
Originally Posted by selfinfliction
the header isn't worth $400--- it's worth about $250 max. we hashed this over for about a month or so in December-January. The stock gasket won't work because the flange on the tog header has too much material cut away from it. this is because the dumbfucks didn't take the info i gave them on the prototype test seriously. here's a picture of the gap with the stock gasket:
another thing you forgot to tell him is that the header doesn't fit flush against the motor period, a gap is clearly there when mounted.
Old Mar 16, 2006 | 11:00 AM
victory_red_SS's Avatar
LSX RWD S/C conversion
just go order that gasket from the dealer. they're only like $3 if i remember correctly
I ordered a new one (only 3 in BC) but it did not come in so I just made one out of the same gasket material for the manifold side. I finally installed yesterday and what a pain getting 3 of the bolts tightened up. I did manage to do the install with out jacking up the car and I have no exhaust leaks. I took it for a run and I really enjoyed the extra kick it has.
I am getting it dynoed this afternoon and I will post the sheets when I get back from the shop.
Old Mar 16, 2006 | 05:23 PM
there's no way you can see a gap on the manifold flange. it's impossible at the angle that is installed in.
my flange was perfect, it was about the only thing that was lol
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
hacadacalopolis
Sep 8, 2015 11:42 PM
