TOGheader dyno results >>>>>>>>>
LSX RWD S/C conversion
Originally Posted by stuffy236
The DP is just the piece from the header to the cat, then its the cat, then the cat back is the piping after the cat.
Does anyone else notice, that in the bottom graph at around 3k rpms there is an increase of 30 lb/ft of torque?!
Am I reading the bottom graph wrong or what. The top two graphs don't seem to show the same amount of torque gain at the same rpm range. It looks like the header gets 30lb/ft above stock at around 3k rpms (in the bottom graph). Stock then catches up at higher rpms. Thats pretty friggin good... If I'm reading this correctly. But Why do the top two seem to be alittle different? Smaller graph or something?
Originally Posted by QuikFKR
I thought 206/hp 185/tq was a little high for a mustang dyno, aren't most ppl getting around 190-195 hp 170/tq on these dynos?
every dyno is different that's why it's important to do all your runs on the same dyno
Originally Posted by victory_red_SS
I hear about a downpipe\cat and then I hear about a cat back exhaust. Are people simply moving the position of their cat because I am thinking that there only needs to be one cat correct???
the downpipe has the cat welded into it. it's all one single piece
the bottom graph was not setup to guage torque, it is only an accurate measurement of the hp
selfinfliction,
you mentioned how headers will so greatly help future mods. whats the consensus on this, will they really greatly increase the gains of other mods? Like that of a cold air intake? or stage upgrade? I'm still wrestling with the idea of buying this. I wish there were more concrete #'s on just how a header would increase the gains of future mods.
for instance if having a header would add an additional 10 hp to a future stage 2 upgrade, then I'd say that would be worth it, but if we are talking only 1 or 2hp then I'm not so sure. I do realize this is impossible to tell at this point though. What about everyones experience with other cars with headers, with other added mods?
i just got off the phone with jon and gave him a few ideas on some stuff. possibly getting a header to someone that has dyno'd with the psi-fi kit to show how much it will help out after some major mods have already been done. we'll see what can be arranged for that situation. but understand that is weeks away if it can happen
Maverick, think of it this way.
When you drop a pulley size, your adding more boost correct? Now, where is all that boost going to heading when it gets out of the engine? straight to the header. At first a stock exhaust manifold may be fine, but once you start dropping pulley sizes, more air has to flow in a tiny amount of space. As self infliction has pointed out, the collector is less than 2". almost the size of one of the primaries (the smaller tubes that the individual combustion chamber gases flow through). Now, without that exhaust restriction, air can move freely and not hinder performance.
Does that help or did I confuse you even more?
If money was no option it would be a no brainer. But just wanna get the most possible return on the mods I do buy, thats all.
I know this is impossible to tell as of now,
That said, IMO, if you only have enough to buy one thing for your car, then I'd be hanging on for the GMPP stuff or even go buy the psi-fi kit. But I would buy this header way before I would even touch a K&N intake for $250. Also bear in mind that that the GMPP stuff is still probably 4-6 months before you can get it, so maybe you buy this in the mean time, and think about that one later....
You can get a cat here and build you own dp for alot less. Most are around $50.
http://www.performancepeddler.com/Ca...Name=Magnaflow
hp = (trq*rpm)/5225
if your not accuratly measuring torque your not accuratly measuring hp.
Originally Posted by n4ggs
uhm... that makes no sense at all,
hp = (trq*rpm)/5225
hp = (trq*rpm)/5225
Originally Posted by chadder
^ werd, dynos measure TORQUE, they CALCULATE HP. Oh, and i also think over 400 is alot for a single header...
they actually measure power
Inertia dyno's measure how strong the car pulls the rollers, and thats torque...
