Transmission Flush...
Old Oct 18, 2009 | 01:10 AM
JAYNO20's Avatar
I am going to be getting a flush done soon here unless any of you guys can tell me it isn't needed... I read on here about the drain/fill plug, but does that drain ALL of the fluid? Also what is the part number of the fluid that should be used? Really any info about this would be a major help. Thanks.
Old Oct 18, 2009 | 01:16 AM
damien's Avatar
If you really want all the fluid out you can pull the axles too, but that's just not worth the hassle.
Old Oct 18, 2009 | 01:20 AM
JAYNO20's Avatar
Will the dealership have a machine to get more fluid out than I could by removing the drain plug?
Old Oct 18, 2009 | 01:25 AM
ColeJJones's Avatar
Bannned
yea, and is the f35 in both the tc and sc using the same kind of tranny fluid??
royal purple 75 90???
Old Oct 18, 2009 | 01:27 AM
recklessactn's Avatar
i used redline 75w 90 with NS
Old Oct 18, 2009 | 01:29 AM
ColeJJones's Avatar
Bannned
with ns??? where can i get that redline ****?
JAYNO20's Avatar
so are we saying its better to have it flushed or is what the dealer gonna do the same as what I could do with the drain/fill plug...?
Old Oct 18, 2009 | 01:31 AM
ColeJJones's Avatar
Bannned
you can use a hose and suck that **** out
Old Oct 18, 2009 | 01:32 AM
JAYNO20's Avatar
what is the part number for the factory fluid so I know what to tell them to use..?
Old Oct 18, 2009 | 01:37 AM
ColeJJones's Avatar
Bannned
the dealership knows all that
Old Oct 18, 2009 | 01:40 AM
JAYNO20's Avatar
I'd still like to know going into it so I know if they are using the right ****...
Old Oct 18, 2009 | 01:44 AM
ColeJJones's Avatar
Bannned
Here you go this is what I could find on MTF for the F35:
Here is the stock F35 Manual Transmission fluid:
-SAAB MTF 0063, SAABs fully syntetic 75W/90 from Castrol
Here are some equivalents (when using an "equivalent" you take risks of causing problems):
-Special 2105 Quaker State Mineral 75W/90 API GL 4EP
-Super Qudralube Quaker State Mineral 75W easy shifting API GL 5 EP
-High Performance Quaker State Mineral 80W-90 also to differential LS-EP. API GL 5
-High Performance Quaker State Mineral 85W-140 also to differential LS-EP API GL 5
-Synchron Fully Synt. Quaker State Helsyntet 75W-90 also to differential LS-EP API GL 5
-SMX-S Castrol gearboxoil fully syntetic 75W/85 API GL 1-4
-EP 80 Castrol gearboxoil Mineral 80W API GL 4
-Syntrax Universal Castrol gearboxoil semisyntetic 75W/90 API GL 4/5 LS
Old Oct 18, 2009 | 01:56 AM
JohnnySasakiMGS's Avatar
The information is in your owners manual. Its a special fluid that the transmission REQUIRES and you cannot use any other type of fluid or it will damage the synchros.
Saturn Manual Transmission Fluid part #21018899.
Last edited by JohnnySasakiMGS; Oct 18, 2009 at 01:56 AM. Reason: Automerged Doublepost
Old Oct 18, 2009 | 02:14 AM
ColeJJones's Avatar
Bannned
not true! i run royal purple. **** runs flawless
Old Oct 18, 2009 | 03:20 AM
Sharkey's Avatar
aftermarket fluids are hit and miss in the f35. some people report great results, others blow things up, and the rest say it makes no difference. there is no miracle oil out there that will make the tranny shift smoother and make the tranny last longer.
the best stuff for it is the factory oil. and flushing is for automatics.
Old Oct 18, 2009 | 04:42 AM
JAYNO20's Avatar
oh ok... so I should be able to do on my own exactly what the dealer would do then? There is only like 2 quarts of oil in the whole tranny and that is it?
Old Oct 18, 2009 | 10:00 AM
06G5GT's Avatar
All they are going to do is drain & fill the same way you would at home. Don't waste your money.
Old Oct 18, 2009 | 10:21 AM
Yeah its like 1.7 quarts or something like that. You need to take the drivers side wheel off and look for the drain plug. And the fill hole should be somewhere above that. You need a long skinny funnel to fill it easily.
Old Oct 18, 2009 | 03:47 PM
JAYNO20's Avatar
ok good info... thanks a lot guys.
Old Oct 19, 2009 | 04:52 PM
JAYNO20's Avatar
does anyone have a picture of the drain/fill plugs on the ss/sc?
Old Oct 22, 2009 | 01:03 AM
getting mine done in the next week or two
Old Oct 22, 2009 | 01:14 AM
leviticus88's Avatar
Search in the how to section, there is a how to that I used with pictures.
I used mobil 1 and its working great in the cold.
Old Oct 22, 2009 | 09:42 AM
stonny9's Avatar
The hardest part will be getting the drain plug out since is is so tight from the factory and not in a good position to get leverage. Hit the allen key with a hammer or use a small cheater bar for better leverage.
If you have done it once before then it should take no more that 30 mins the second time.
RaginChopsuey
Oct 27, 2015 01:27 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
