Is this true?
Old Apr 23, 2013 | 02:48 PM
MrSlickSter06SS's Avatar
Question Is this true?
So I have read if you have a bad MAP sensor, you can also throw a P0300 code which leads to misc. misfires within the spark plugs/coil packs. My new MAP sensor should be here thursday, but only codes I throw are the P1182, ad P0300 so I dont know* it makes sence to me lol.. Seeings how I have new plugs, and coil packs.. What do you guys think?
Old Apr 23, 2013 | 03:06 PM
in for answers i'm in the same situation! new plugs and coils but still throwing these codes sometimes and getting random misfire
Old Apr 23, 2013 | 07:41 PM
BUMP; When you quarter throttle the car does it bogg down? like you cant speed up enough to even pass someone going 35 on the road lol?
Anyone have any thoughts on this? Please, and thank you.
Old Apr 23, 2013 | 07:43 PM
Bump.
Old Apr 23, 2013 | 07:55 PM
user 72239's Avatar
When i got the p0300 code, I bought and regapped plugs at .032 and it went away. However, this was on my LNF not my LSJ
Old Apr 23, 2013 | 08:01 PM
yellowsupercharged06's Avatar
Hey guys what plugs are u running ?
Old Apr 24, 2013 | 10:19 PM
I am running the Denso iridium Power plugs gapped at .030" part# IK20#4
Old Apr 24, 2013 | 10:45 PM
•Model: ND-IK20-4
•Manufactured by: Denso
Old Apr 25, 2013 | 02:41 PM
BUMP: I just installed the new MAP sensor so Riceburner I'll be keep you up to date on the progress
Old Apr 25, 2013 | 06:33 PM
Well to answer my own question yes it will! it infact does throw a P0300 code if you have a P1182 code. I have went through thick, and thin with this thing and come to find out I had stuipedly put my vaccum lines on the wrong port for the supercharger, and bypass/actuator valve. "DumbaAss!" yes I am lol but had I not given up on fixin the car I would have never even known.. So now that I switched the two lines the bypass, and throttle body now work in sequance rather then agaisnt each other.. I have no more codes, and my god how I forgot how hard the car pulls Lol. I hope this helps everyone else make sure you double check even in overwhelming situations! peace!
denny
Apr 4, 2026 07:55 AM
themacguy
Aug 26, 2015 07:18 PM
