Is this true?
So I have read if you have a bad MAP sensor, you can also throw a P0300 code which leads to misc. misfires within the spark plugs/coil packs. My new MAP sensor should be here thursday, but only codes I throw are the P1182, ad P0300 so I dont know* it makes sence to me lol.. Seeings how I have new plugs, and coil packs.. What do you guys think?
Anyone have any thoughts on this? Please, and thank you.
Well to answer my own question yes it will! it infact does throw a P0300 code if you have a P1182 code. I have went through thick, and thin with this thing and come to find out I had stuipedly put my vaccum lines on the wrong port for the supercharger, and bypass/actuator valve. "DumbaAss!" yes I am lol but had I not given up on fixin the car I would have never even known.. So now that I switched the two lines the bypass, and throttle body now work in sequance rather then agaisnt each other.. I have no more codes, and my god how I forgot how hard the car pulls Lol. I hope this helps everyone else make sure you double check even in overwhelming situations! peace!
