Turbo Build: The Disassembly
Haha..
there are farrrrrr faster on this site...
Eventually, i want it to "rock worlds"
Everything is basically on the car... all the "hard parts"...
Thing is looking sick! I just need to re-tighten some bolts and plug in some things...
Its been raining, but what ev... I want this thing done...
I think the bumper is going to be a bitch to get back on.....
Last edited by ShortStack; Mar 18, 2009 at 10:48 AM. Reason: Automerged Doublepost
Havent been taking them... i just gettin the work done because i want this thing moving... ive been workin my ***** off.
ill get some final pics though for sure
Last edited by ShortStack; Mar 18, 2009 at 11:20 AM. Reason: Automerged Doublepost
what size (AR) is the exhaust housing?
v-band out put, 5bolt.....what style is it?
also, the tune is just unsafely conservative.
there is a point in witch pulling spark starts to become unsafe as EGT's get out of control....they are at that mark.
max 9 deg of advance at WOT.
and my car ran like a dream on their tune... i just needed to dial in the maf and fix my afr to my liking...
dont let this worry you shortstack. are you 07 or 05-06? the tunes are different. i have 07.
well as long as you monitor
1. KR
2. AFR
3. EGT
you'll be fine. and just so you know, the car is such a beast on 15lbs you will be plenty happy with it, 22psi is just silly to me... unless you have part ownership in BFG i would leave it on low boost.
i have made all of my kills on low boost...
1. KR
2. AFR
3. EGT
everything is hooked up!
The car even started! (lol) There seems to be a weird noise coming from the intake mani (i think its the dip stik hitting) but then i discovered that oil is just POURING out....
its coming from the drain system, i think.
It was wayy to dark to get under the car to tell, but im going to take a look at that tomorrow.
Car sounds ALOT different.. is this normal?
Thanks hungryhip... i appreciate your help.
but you are not factoring in the adders... i have that same tune i even sent you a copy of mine, which you never responded. i was seeing up to 23 degrees with the adders.
when Kevin stuck his foot into her, she hit 9deg.
2nd gear and into 3rd.
the adders are set up in a incorrect manor, you set the table and then use the "adders" to pull out when needed.
not the other way around.
1. KR
2. AFR
3. EGT
1. KR
2. AFR
3. EGT
solid....meh...sure......potential however....LOTS.
any who, OP. glad you got her going.
describe this "odd" sound.
Just a note for those trying the intake mani - you can take out the bottom cross bolt from where the alternator was, without fighting with the other two (that you need to take the IC pump off for). Saved me some time, might save others.
post pics of were its leaking from? so we can help better.
hey 06
thats true after i posted i thought about it and his tune could be different i havent seen his. but i agree with you. and i have mostly zerod out my adders but i like my timing to be what i say it should be not the adders.
well when i was running the hahn base tune it would break the tires loose in second (235/40/18) now on my own tune, with meth traction is a joke i dont even turn the boost up it just cost to much for tires (not to mention the trq steer in 3rd @ 100mph) now i consider that to be some what of a beast (in a 4cyl scene)
Last edited by hungryhip-ccp; Mar 19, 2009 at 05:43 AM. Reason: Automerged Doublepost
06, hip i think might have the right idea about the valves making the noise, it almost sounds like "sticky lifters"... but a little different, ill see if i can get some good sound.
I will try to get home ASAP and take some pics.. but its coming from the area of where my drain is... i lost a good amount of oil so i need to refill her before i can find out exactly. Hopefully its just one of my clamps...
Idle bounce around at first... then it started to level out after about 20 seconds... then it started smoking (i figured this might happen) but then it just started sound funny.. then i realized alot of oil came out... there was a little bit of oil coming from the top of the turbo, but not nearly enough to amount to what came out...
Looks like ill be checking connections today.
not to thread jack but, im contemplating ordering my kit today but after reading all this im kind of scared.. hearing the tune is sketchy and different things... now am i just bein paranoid or should i just wait...
btw i read all the pages here and sounds like your stuffs coming right along! hope everything comes together and no bugs!
any canned tune is going to be sketchy. I had no other way to get my car tuned so this was my only choice. your hearing that the tune sucks from someone who has really high expectations. Its not like its unusable or anything.
Anything you do to your car is going to have problems... I have seriously only worked on my car for about 6 months, and honestly, thats not going past changing the injectors.. and ive done this ALL myself... your going to run into problems no matter what you do.
you just have to be prepared to take whats given to ya and make it work.
yeah im just worried because i have no real way to get tuned myself...
i'm not worried bout puttin it together thats easy
oh well screw it, its all a learning expierence and something new!
anywho how's the build coming?
