Turbo Build: The Disassembly
its alot of work... its not the complication of putting things on.. its just the amount of time it takes to do so...
i finally got everything plugged in last night.. but i started leaking major oil from somewhere... Im going to check that out after work. I figured there might be more problems.. but as of right now it just seems like the oil drain is the problem....
I might have just missed a clamp or maybe need to do some leak prevention on the fittings..
Also, the tune is completely drivable...
Last edited by ShortStack; Mar 19, 2009 at 11:46 AM. Reason: Automerged Doublepost
Yeah i figured it would take some time to do it all, im not to threatened by that haha i just pulled the car out of garage for the first time last week (glory of living in PA, bad winters!)
well i hope you get the oil draing figured out man, its probably just eating away at you to get it out on the road for alil "Test" run
Edit:
Im glad to hear that... maybe one of these crazy devils at the Ohio meet can shed some light on the subject
Edit:
When the car started i went ape poo... but then as soon as i saw the oil leak i was like horse vag! Ill get it figured out though... i just need to go through and tighten some things.
what 06 was refering to is the timing on his friends car could be considered dangerously low as far as raising egt's.
i have a tune from them that is most recent and it was not dangerous in any way in my eyes. just conservative. hahn must of made some changes since then.
hope this helps you out!
also heres a link to my build thread... it may intrest you!
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/hungryhip-ccp-level-v-hahn-turbo-build-pictures-56k-stay-away-129632/
Your thread helped me get my oil lines all setup.. thanks for taking the time to do that...
Hahn so far has replied within 20 min of me emailing them...
they explained the noise of the intake mani as well...
they said the oil drain pipe off the turbo may be unevenly tightened.... I have a feeling thats where its coming from..
you put the little paper gasket? i added a little gasket sealer to each side, not no where near enough to clog the drain just a light light film for good measures... i have a feeling that were it is coming from.
so, did you install a egt on the hahn manifold while it was off? or at least a 1/8 npt with a plug? i sure wish i would have... now i have to take it all back off
i have the gauge just no bunghole hehe
Next week, im going to get rotated mounts and probly a tune (i really just want to get hptuners).
I need to get myself some gauges and stuff... Its gonna be a PAIN getting all that **** off again.
that damn gasket stuff i got is ******* messy.. everytime i tightened the tb down it ended up getting all over and i had to take thething off about 4 times to clean it off of the TB plate... i barely put any on too...
i did use the paper gasket... i really think the oil drain is the problem though... All i know is that im gonna be having some fun putting the bumper on haha.
i have a open bunghole on my dp that i cant find my rear o2 to put back in.. haha... hopefully it doesnt do that stupid random open loop like yours did.
I need the 3" exhaust as well.....
:cuss ing:Tightening up the oil drain pipe, the bolt snaps, and is now stuck inside the turbo..
it got too dark before i could try to drill it out...
This is getting annoying..
But what ever, ill work through it.
Last edited by ShortStack; Mar 19, 2009 at 08:54 PM. Reason: Automerged Doublepost
Hey I am Kevin, one of the local Hahn cars Bryan (06black) speaks of.
I have something that may be able to help, the clamp that holds the center section of the turbo together is pretty loose from the factory. The torque spec is only some low amount of inch pounds, but i found that mine leaked a good amount of oil. when your under there, tighten that clamp just a little bit, like we are talking hand tight here.
fixed my problem.
good luck with that bolt!
fixed my problem.
fixed my problem.
fixed my problem.
Hungry thanks for the "nevre relaxing" advice... i'll be placing my order tomorrow!
i bookmarked your build thread and it will be on my laptop beside my car haha
Short man hopefully these are the ONLY bugs you have man!
I will.. im Sure...
These things are now just starting to get annoying... like i knew there would be problems.. but come on? Im have not used any power tools i dont know why these things are breaking...
Im tiny.. lol...
Im tiny.. lol...
fixed my problem.
fixed my problem.
before you drill try an easy-out its a left hand drill bit that looks like a screw kinda and it grabs it and threads it out, if that doesent work then try a drill bit.
im not talking down on anyone here but for the others sake and them being scared away by problems, i would like to add that i am a mechanic and i didnt have one single hahn related problem in my build... it simply bolted on and i drove off, not a oil leak, boost leak, nothing ran ****...
if you are capable and work on cars for a living or are going to take it to somone professional for install dont be worried this is a very very solid kit that is true bolt on performance...
To be honest, Ive never work on a car.. and i was able to do this..
I obviously made some beginner mistakes.. But anything can be fixed.
Easy out.. where can i get one? i asked for that at home depot but they just gave me a drill bit...
Actually thats what i bought, but they told me to drill a hole first...
Last edited by ShortStack; Mar 20, 2009 at 02:17 PM. Reason: Automerged Doublepost
na, just noticed it was loose. i did have some oil leaking from that area but i was told by hahn it was the way i had my hoses routed that the turbo couldent drain properly after engine shut down and i would get a drop or two coming from there. nothing like what you have explained you obviously have a good size leak somewhere. i hope you fix it soon, i cant wait to see the excitment in your posts once you drive it for the first time...
hey you do have a wb right, if not do not go into pe untill you get one, also you need to monitor knock via a interceptor gauge and set your annunciator to go off when 1deg or more of KR is introduced.
you have to remember your pushing some ponies now, if your knocking or lean that motor is gonna go bye bye real fast,
my car was commanding a 12.20 afr from hahn and was running a 12.0 afr with a little knock, cause im on 91 and they tuned on 93...
just you have to remember this is a canned tune and somethings need to be confirmed before entering wot... afr, kr, boost. and preferably egt but what ev...
yeah yeah a little one in the broken bolt itself. i thought you meant your going to drill the turbo housing.
Last edited by hungryhip-ccp; Mar 20, 2009 at 02:21 PM. Reason: Automerged Doublepost
Oh god No.. lol....
im wondering if i used some quick drying epoxy or something on the bolt so id have something to grab it with?
I just really hope i can get this bitch out.. if not... hello Band clamps + gorilla glue
jk.. but seriously this is whack.. haha..
I do not have a wb... Ive been REALLY needing one though... I might hit the gas a few times but generally ill make sure to stay out of pe.
jk.. but seriously this is whack.. haha..I do not have a wb... Ive been REALLY needing one though... I might hit the gas a few times but generally ill make sure to stay out of pe.
I think everyone wants this car running.. haha...
Dude ive dealt with this **** for over a week now.. i can deal with another broken bolt...
ill find a way to get it out...
