turbo manifold
Old Jan 14, 2009 | 05:20 PM
  #51
schamsy's Avatar
Originally Posted by Zooomer
The ZZP manifold (version 2) is pretty much the best value out there. We made 465WHP with it, which is more than any other manifold out there. With a recently lowered price, you won't find better.
http://www.zzperformance.com/cobalt_...=867&catid=155
I dont have their manifold, but it looks like an excellent design!!! Wow! if I ever go turbo I will buy theirs.
Old Jan 14, 2009 | 05:22 PM
  #52
lsjwannabe's Avatar
Ok so to some up the thread you call our kit junk and a waste of money/time
I post up info thats supposedly misleading or hiding something, becuase its not like its a widely know fact that the kit comes with the fpr as seen on the site.
I respect the fact you actually do flow test the pumps as did we and the walbro fit the job for my car and many others.
I also posted that the walbro is only a option not required or hard bundled.
The whole boost referenced thing is great, i ran 25 psi thats why i went with this. The multiple customers that have bought this kit all have something in common. They all run 23+ psi.
Then you call the kit unreliable and more or less a waste of money. You ever heard of a problem with our
kit? I haven't please do tell if you did though.
wow just wow.
Old Jan 14, 2009 | 05:31 PM
  #53
Matt M's Avatar
wow just wow.
I think the "less reliable" comment was aimed at the Walbro, in which case it is in fact much less reliable than a stock pump.
Old Jan 14, 2009 | 05:32 PM
  #54
Zooomer's Avatar
Supporting Vendor
Easy. I didn't mean your kit is junk, I have never seen it. From the pics it seems nice.
What I am saying is that a return style fuel system isn't needed for any reason that I have seen to date in this market. If you make a return system, then that would include your kit as well. That doesn't mean it's bad, I am just saying it's totally un needed.
By misleading I'm saying that you are using the fact that you changed fuel pressure to sell a return style system. This implies that you need this system to do what you did and you can tell from some of the consumers posting here that you have done intellectual damage. There are people here that actually believe a return system at the same pressure offers increased fueling to the engine. Clearly you don't want consumers misled or scientifically illiterate do you?
It would be like me selling a billet rail to run some custom larger injector and posting up dynos showing I cured the lean problem with running a 2.8" pulley. Then someone else saying "the billet fuel log is not needed and the dyno graphs are misleading because you can buy 60# injectors to replace your stock ones and do the same thing" Get it? You're using the fact that you changed fuel pressure to sell a return style fuel system when the two aren't really related. Now I have no problem with you selling the part but don't get on the boards and tell people that it is needed in applications where it isn't. It confuses people and makes them less knowledgeable about the cars.
In terms of reliability, anything you do to mod your car makes it less reliable. Especially fuel related things like Walbro pumps. They are probably 100x less reliable than OEM pumps. Some people need more flow and the risk/cost is worth it but if you already have a pump that better it's not a very good buy. Since vendors are usually the only ones to flow test pumps, our responsibility to provide consumers with accurate information is greater.
Old Jan 14, 2009 | 05:36 PM
  #55
lsjwannabe's Avatar
By misleading I'm saying that you are using the fact that you changed fuel pressure to sell a return style system. This implies that you need this system to do what you did. It would be like me selling a billet rail to run some custom larger injector and posting up dynos showing I cured the lean problem with running a 2.8" pulley. Then someone else saying "the billet fuel log is not needed and the dyno graphs are misleading because you can buy 60# injectors to replace your stock ones and do the same thing" Get it? You're using the fact that you changed fuel pressure to sell a return style fuel system when the two aren't really related. Now I have no problem with you selling the part but don't get on the boards and tell people that it is needed in applications where it isn't. It confuses people and makes them less knowledgeable about the cars.
Show me one post where i told someone they need it thats "not qaulified". Now you are just being ignorant and putting words into my mouth that were never there.
I can show you multiple pm's of me telling people they don't need it.
Old Jan 14, 2009 | 05:48 PM
  #56
06blackg85ss's Avatar
and as for the fuel system quote...... I'm not some idiot, I do know how our stock fuel system works. I had to pull everything out of the tank to fix it anyway so I went with a bit better pump, I know walbro's aren't the best, but it was what I had laying around and just happened to be an almost direct fit.
and seriously zzp guys, you're not helping your cause with some of your posts, you're just digging a deeper deeper hole with the people that could actually help your business
Old Jan 14, 2009 | 06:01 PM
  #57
sleeperbalt's Avatar
So zoomer you are running the FPR in the line at the fuel filter that returns it back to the tank an getting rid of the check ball?
If so?
Thats perfect! Its simple and will work great! so just run a vac/boost line back to the tank?
Old Jan 14, 2009 | 06:11 PM
  #58
Zooomer's Avatar
Supporting Vendor
I don't know what you believe our 'cause' is or how you could know much about our business but I can assure you that my primary goal is turning this market from a lot of ignorance to some good knowledge. When we're out running 12's with basic mods and 11's with our turbo kits people are going to want to know what they are doing wrong or we are doing right. I'm merely giving our facts and trying to educate people on some things, albiet I'm not very good at it.
If so?
Similar to that, yes. You don't even need to run a vac line, you can use the EVAP. Crazy easy.
Old Jan 14, 2009 | 06:16 PM
  #59
I guessing you dont want to show a pic do you?
Will you be making a bolt-on reg kit anytime soon?
Old Jan 14, 2009 | 06:19 PM
  #60
well what I believe is my own business. and as for your "proof" of your claims, you still haven't provided any solid proof (dyno sheet, yeah, but no temp, correction factor, or smoothing shown, dyno pull that doesn't show a full pull nor the dyno screen) I'm not saying your a lier, I'm just saying prove your not. By saying "cause I said so" like I've seen you post, well, that just doesn't cut it for me, and a lot of others. Now I never claim to be a know all end all LSJ expert. but I've been around the block when it comes to cars, and I know what these motors are capable of and what they are not.
now I'm used to dealing with skeptics on here, so when I post up my info, I put everything out in the open unlike some other people on here, which of course is there own business. People wanted different dyno's I geve em that, people wanted full dyno sheets, I gave them that, people wanted video I gave them that too. I don't even run a car business, I just do this for fun. I work 2 jobs and 70-80 hrs a week, still work on my own car, and every other damn cobalt in pretty much NY and I still have the time to put that stuff up.
I'm all about making these cars faster and bringing them out from under this ricer shell people have put them in.
I dunno, I'm tired and rambling now, so I'm done.
Old Jan 14, 2009 | 07:24 PM
  #61
WickedSS2005's Avatar
Damn, and I already called a truce w/ Matt M because it was getting no where.
I needed a good read. Thanks all. I'm out
Old Jan 14, 2009 | 08:23 PM
  #62
Matt M's Avatar
I understand what you are saying about providing further proof, and we will. In the mean time, take a look at what we've done in the 3800 market. Yes, I realize that LSJs are not 3800s, but ZZP is ZZP. A few years ago, we were in the same boat with skeptics running rampant. Initially, we had a tough time convincing people to believe what we are saying from time to time. After we backed up everything that we claimed, that all changed. Now the 3800 market can take what we say to the bank because we have gone to great lengths to prove ourselves time and time again. Some examples would be our supercharger dyno used to test supercharger design and modifications as well as intercooler testing. We built a belt grip tester to compare all available belts and pulley designs. We've done extensive fuel pump testing. We brought aluminum heads to market from start to finish. We also modified several 3800 cars. Pretty much, if it can be tested, we've tested it. This has paid off tremendously concerning our ability to successfully modify 3800 based cars. To date, we hold the record for the quickest and fastest M90 powered 3800, quickest and fastest fwd Monte Carlo, quickest and fastest fwd Impala, and quickest and fastest overall fwd 3800. Our twin-turbo drag car has dyno'd 753 whp and ran 8.65 at 159mph on a stock 3800 bottom end. We do this to demonstrate how much power can be made without spending extra money on unneccessary parts. Of course we don't expect customers to try to make over 750whp on stock pistons, but on the flip side, we can rightfully consider it silly to install forged pistons in a 12 second car. That is exactly the type of situation that Zoom is attempting to prevent. Unfortunately, people who believe otherwise may get upset in the process.
Old Jan 14, 2009 | 08:31 PM
  #63
WSFrazier's Avatar
Between Paul's car running over 400whp for over a year now on stock motor, and Bryan using stock fuel pump/system and making 484whp... I am pretty sure people realize what is really needed, and what isn't.
Old Jan 14, 2009 | 08:46 PM
  #64
qwikredline's Avatar
You can't make 486WHP on a stock FP unless you raise fuel pump voltage which is what I stated previously. Furthermore the stock pump at stock voltage cannot supply enough fuel to max 79# injectors so the system isn't matched.
On the 465WHP, we did it with our smaller turbo full exhaust. We dropped the exhaust and were setup to make over 500WHP but the clutch didn't hold. We'll surpass 500WHP easliy with our twin charged kit shortly. In terms of your mathematically impossible I have a few comments:
1. We already did it and will make much more. How is your math going to show me that what we did, didn't happen? It was repeatable.
2. Please post your math here so I can debunk it for you and everyone else here and we can move on.
3. ZZP has been doing things we were told is 'impossible' for years. This is no different and we'll be at track running the times to back the dynos when the weather warms up. I hope your impressed and spend as much time praising the acomplishments as you have posted calling us out.
We cannot guarantee the fitment of turbos we haven't used on your car. It's not possible to test every turbo because there are too many different housings and configurations. I'm not concerned about you 'breaking' the 465WHP mark. I don't consider it that much of an achievement. We did it with about 1 month of work so I expect it to be surpassed easily. I wasn't trying to challenge you, I was posting because I hear every day about people's 'plans' and they aren't realistic. Maybe you're different.
You also mentioned that you were going for over 500, so our 465 wasn't impressive. Maybe true but the other manifolds have not proved themselves at these levels. I was only posted to show that we're making good HP.
Depends on the year of Cobalt but that is correct. That's how this market is though. Rumors and myths run rampant. We're hearing about stock fuel pumps making nearly 500WHP at stock voltage, then other people are downgrading to Walbros and thinking they are 'modifying' their cars. Other people are excited about this return style fuel system and people have no clue. You don't need that. It's extra crap. Most people don't even know how the stock fuel system works or why it's pointless to run a return style setup. Used to be that 60# injectors made the #4 piston lean (no knowledge of fluid pressure laws), now 60's are the norm. Some posted that the stock IC core was restricting the TVS, no mention that people were making over 100WHP more than that through this core. Then we read that the stock intake manifold doesn't distribute air evenly, no testing or evidence, just rumor. Later we read that cams only make 5HP on cobalts with dyno charts to "prove" it. Posts about spraying water or windshield washer fluid in your engine are daily, probably millions spent on this with no gains. People just don't understand, yet they back it like their sister's honor and won't take ZZP up on our $1000 water injection challenge. It's a full time job debunking the bad information around here...
The fuel pump doesn't determine fuel pressure, you should have called us to explain the fuel system to you and save you the downgrade and cost of buying the Walbro.
After a while the BS you post from ZZP gets a bit tough to take. From your own words in other posts, you dont understand how GM's Option B works, so its hard to read this Turbo stuff, and have you contradicting yourself and making extravagent claims. A little "Under promise, Over deliver " might work for you. IMHO your claims are just that. Claims.
Old Jan 14, 2009 | 08:59 PM
  #65
WSFrazier's Avatar
Question for you guys ZZP...
You keep saying you did 700whp+ on stock bottom end on a 3800, what was done to the top end of the motor?
I am assuming top end work was done, since you keep saying stock bottom end and not motor.
Old Jan 14, 2009 | 09:13 PM
  #66
Josh@ottp's Avatar
Just a few thougths off the top of my head. Zoomer your pump info is innacurate/misleading. You talk alot about pump voltage but don't post any specs on what the voltage was during your test...
Here is some good pump info on the walbro's, and you can see that they flow differently then what you listed.
All of this talk about walbros being a bad pump is bs. Walbro has gotten a bad rap from all of the copy cats from china, you just have to make sure you have an official pump. Walbro actually makes oem pumps for alot of cars, C5 vettes come to mind.
Next you talk all about pressure but not so much about flow... The return style system is designed to flow more fuel to the rail while giving the user full control over fuel pressure right under the hood. It's a hard system to beat for the money.
Old Jan 14, 2009 | 09:32 PM
  #67
Area47's Avatar
Rent me! per hour
when going above 17.6 psi of pressure, the lsj ecm runs off the last cell on that map before it, more or less runs off the scale. maf does this, as well as the timing table. you are only seeing a portion of the facts when you open up the hpt files on an lsj.
this is what happens you when you outrun the tables with air flow. this was proven long ago. you "should" have seen this with your basic twincharge pulls on the rollers. i see this everyday i run the engine up to 8k rpms in the timing table. psi is irrelevant.
http://www.kinsler.com/Cat_32_Pgs/Ca...l_Pump_Pgs.pdf
Old Jan 14, 2009 | 09:44 PM
  #68
Josh@ottp's Avatar
Good find.
Old Jan 14, 2009 | 09:55 PM
  #69
Area47's Avatar
Rent me! per hour
i know where to look for true answers from trusted sources
Old Jan 14, 2009 | 10:34 PM
  #70
Matt M's Avatar
Stattama STR4 turbo cam, balance shaft removed, ARP head studs, Cometic MLS head gaskets, ZZP aluminum heads, Holden lower intake, ZZP custom upper intake.
You are correct that Walbro builds oem fuel pumps. It is also correct that they once built quality fuel pumps for the aftermarket. Unfortunately, the aftermarket/performance division of Walbro was sold a couple years ago. The defective pumps are being sold by authorized Walbro dealers who purchased them from the Walbro aftermarket pump division. We used to sell them, but when the quailty decreased to a level unsuitable for retail sale, we dropped the product.
Old Jan 14, 2009 | 10:43 PM
  #71
Witt's Avatar
x2. Laughs are abundant with us here as well.
Keep up the good work guys, it gives me something hilarious to read when I'm bored at work.
Old Jan 14, 2009 | 10:45 PM
  #72
Matt M's Avatar
Where do you come up with the idea that it is innaccurate/misleading? FWIW, we ran 18 volts to support 465whp with the stock pump, but it doesn't make any difference what the voltage was as long as it was high enough to maintain the correct fuel pressure. 17 volts would have worked just as well as 20 volts. Of course you can't run too much voltage without risk of damaging the pump, but that is a completely different issue.
Old Jan 14, 2009 | 10:51 PM
  #73
Josh@ottp's Avatar
His pump info is missing what volts the pumps were flowed at.......it's like a dyno graph without the correction factor being shown.
Old Jan 14, 2009 | 10:56 PM
  #74
Matt M's Avatar
The MAF table runs "off the scale" at 17.6 psi? And you are laughing at us?
Of course we found the other issues you mentioned, which is exactly what we solved with our boost-referenced fuel system mod.
Old Jan 14, 2009 | 10:57 PM
  #75
bwalker0510's Avatar
i cant believe how far this thread has been brought of course. and not by young teens who think they know whats right over wrong, but by some really good/respectable vendors. you guys need your own agruement "i know more than you" thread but for real come on guys. he asked for OPINIONS on the best turbo manifold and its down to shitty/nonshitty pumps and who made what with what and your **** dosent work or is pointless. people no matter what proof you have will always disagree with something that didnt come out of there mouth and after proven wrong will back it up ONLY due to pride. lets get this back on track.
p.s. dont ban me or charge me extra for parts now
