turbo manifold
Old Jan 15, 2009 | 12:36 AM
  #101
Matt M's Avatar
Originally Posted by car_guy_09
OTT backs everything with any proof possible along with pretty much anything else they can through in to proof their point, You guys just make a bunch of claims and act like you are the almighty LSJ gods, With no solid proof, Then when questioned you start talking about your 3800 achievements, Thats great and all but it has nothing to do with the LSJ.
In my earlier post, I already addressed this. We are in no way acting like LSJ gods. We are here to learn what we can and teach what we know.
He is talking about the walbro numbers
I understand that, but there is absolutely no place in the charts that use the same voltage and tests at the same pressures that we did. Aside from that, Zoom did not even post the unit of measurement being used in our tests. The tests were not to provide a specific flow number. They were done to compare different pumps under the same conditions. Therefore, I find it ridiculous to read someone posting that our calibration is somehow off.
Originally Posted by WSFrazier
Why do you think you are being looked down upon? You guys are doing this to yourselves. Even if your right, or wrong... you need to know when to just shut up. I can't believe you guys are actually trying to run a reputable business this way. You look like immature tools.
To people that disagree with us or already dislike ZZP, we might look immature. However, I can assure you that there are plenty of people reading who take notice of what we say and will learn something from it. I challenge you to find something immature that I have posted in this thread and quote it here. You are letting your emotions decide that I must be a jerk because you don't like the fact that I openly disagree with others on this forum. It's unfortunate because your name calling is what really brings the thread down. Please try to have a discussion without resorting to that type of post.
Old Jan 15, 2009 | 12:37 AM
  #102
car_guy_09's Avatar
Agreed...
Old Jan 15, 2009 | 12:51 AM
  #103
lsjwannabe's Avatar
Matt, see post #55
Not you, but worse your boss made an accusation totally unfounded and contrary to what I posted.
Old Jan 15, 2009 | 12:55 AM
  #104
Witt's Avatar
Originally Posted by Matt M
We didn't do either of those on our setup.
With the lack of an explanation I have to conclude that the use of "magic" is being used to provide pressure above what the stock regulator offers as well as a variable in order to drive fuel pressure in a ratio to manifold pressure.
Old Jan 15, 2009 | 12:58 AM
  #105
Josh@ottp's Avatar
Because OTT trys to sell parts that are not required and ZZP doesn't?
Seriously, if people are set on running a return style system, there should be a lower priced option. Maybe we will come up with something along those lines if the demand is there.
I'll start a different thread because we are not helping the OP with our debate.
But how is it that you are comparing their numbers to ours? And where do they have an oem Cobalt pump on their list?
Oh so you want to call us out on a product but now you want to make your own version? With regards to the pump flow numbers, your walbro numbers are way off of what the other companies list.
Old Jan 15, 2009 | 01:01 AM
  #106
Zooomer's Avatar
Supporting Vendor
Originally Posted by fast98
Just a few thougths off the top of my head. Zoomer your pump info is innacurate/misleading. You talk alot about pump voltage but don't post any specs on what the voltage was during your test...
Here is some good pump info on the walbro's, and you can see that they flow differently then what you listed.
All of this talk about walbros being a bad pump is bs. Walbro has gotten a bad rap from all of the copy cats from china, you just have to make sure you have an official pump. Walbro actually makes oem pumps for alot of cars, C5 vettes come to mind.
Next you talk all about pressure but not so much about flow... The return style system is designed to flow more fuel to the rail while giving the user full control over fuel pressure right under the hood. It's a hard system to beat for the money.
I find it amazing that you state my numbers don't match without me listing the voltage, time or unit of measurement. The test you referenced is a generic test for a couple very specific applications. Not all that applicable here. At ZZP, when we're testing something we look for real world data. We want to know what the pump will flow in the used application with the same voltage the car is likely to see. Granted the cobalt pump doesn't see 13.8 volts but with the proper rewire (required for any serious build) it would. So I provided data applicable to the situations we're talking about here.
also to note is that pump which do better at higher psi usually scale better with increased voltage. This would put the advantage to the cobalt pump as well. But I'm rambling and getting into things we do in house without normally posting about it because most people don't even understand what we're talking about or why we're doing it.
It's much easier to sell someone a Walbro pump and tell them "it flow more" than to get into these technical discussions. Keep in mind, ZZP is not selling anything here. We have no incentive to be lying about this. Ask yourself, does a guy telling me to keep my money have more incentive to provide false information than a guy trying to sell you something? Of course not. in time people will come to know ZZP as a no bullshit shop that has experience and technical knowledge beyond most shops. Notice how the haters say things like "your hurting yourself" or "you guys are arrogant" or "you're not the gods of LSJs" but not a single person comes in with real technical knowledge. If somone doesn't understand basic fluid dynamics and when you talk about it they slam you with petty bickering, it kind of goes to show where the education level is.
Originally Posted by Area47
when going above 17.6 psi of pressure, the lsj ecm runs off the last cell on that map before it, more or less runs off the scale. maf does this, as well as the timing table. you are only seeing a portion of the facts when you open up the hpt files on an lsj.
this is what happens you when you outrun the tables with air flow. this was proven long ago. you "should" have seen this with your basic twincharge pulls on the rollers. i see this everyday i run the engine up to 8k rpms in the timing table. psi is irrelevant.
We're way ahead of you Area, although your information is accurate for the most part. ZZP dealt with running off the MAF tables in PCMs before the first cobalt was ever sold. This knowledge led us to run a larger MAF tube to lower the frequency at a given airflow and then recalibrate the PCM to compensate. The other alternative is to run a mini-AFC that some of you may remember on ZZPs site years ago. You can PM me Area if you need more details to fix your build and I'll help you out.
Originally Posted by ShortStack
So taking the extra step to ENSURE nothing goes wrong is bad?
I have answered this and I'll do it again. The Walbro is WAAAY less reliable than stock and any modification to the fuel system will be less reliable than stock. when an increase in fuel is needed, you have to make changes to the very reliable factory systems on the car but if no change is needed, then you are INCREASING the chance of failure by adding parts.
example would be buying a brand new car and going to autozone to change out all the parts under the hood to ENSURE, as you stated, that you car would be reliable for a trip around the country. This would be a fools move and demonstrates exactly my point. Thus your logic is backwords.
But if they are running low pressure the walbro flowed better...
Which is what these people with (mods that dont require it) are using.
This is meaningless because the stock pump flows enough to max the injectors. You could run 100 pumps to the same injectors and flow 100x more but it wouldn't give the engine any more fuel. That's my point, the Walbro will not be a better pump in any situation. With 60# injectors the stock pump can provide fuel till they go static. if you up fuel pressure, the stock pump flows more.
Again, based on what? I didn't say if we measured gallons, pints, ounces, liters, CCs, barrels, cubic feet, etc. I also didn't post the time the pumps were tested for. Is the scope of your fact collecting limited to comparing one number to another? do I need to do the conversions for you so you can compare to other sites? Do you buy car audio based on wattage ratings from manufactures as well? I simply cannot believe people are calling us out as being ignorant when we have to respond to posts like this.
Making our own version is all but about an hours work, some pictures and a web site update. We've already done it on the twin charged cars. We simply don't offer it because no one in this market we've seen needs one and to sell it as an "upgrade" would be terribly misleading as evidenced by the consumers who posted in this thread.
Old Jan 15, 2009 | 01:07 AM
  #107
ShortStack's Avatar
THe mini-afc that cobalt addiction pulled because everyone and there mothers was saying it was a peice of crap?
Or was there one you developed yourself?
I didnt say i was gonna replace my fuel pump...
I was going to uncap the end of my fuel rail...
Last edited by ShortStack; Jan 15, 2009 at 01:07 AM. Reason: Automerged Doublepost
Old Jan 15, 2009 | 01:12 AM
  #108
berto's Avatar
I'd go with ott or HAHN dude
Old Jan 15, 2009 | 01:13 AM
  #109
Zooomer's Avatar
Supporting Vendor
The AFC was pulled by CA because it was no longer available from the manufacture (Easy Performance). They went into a redesign and didn't release the 3.0, you'd have to email them as to why. Easy Performance is a break out company from ZZP. Digital Ken, a nuclear engineer and Wizbang, an electrical engineer brached out to specialize in electronics.
uncap the end of your fuel rail and what?
Wow, I find it hilarious that every ZZP employee seems to come out of the wood work.
Because there are a lot of engineer type technical people in the company that don't believe us when we tell stories about threads. They simply cannot believe it until they read it for themselves and then probably get so frustrated watching the chaos of ignorance that is almost celebrated around here that they have to post. But I believe a good majority of the educated people, or people wanting to learn merely read and leave the posting to the loud mouths. No one with any understanding of physics could read this without investigating or already knowing that ZZP is on top of our game. This is what we are proving and improving with the exchange of information.
Old Jan 15, 2009 | 01:15 AM
  #110
ShortStack's Avatar
Do whatever http://www.ottperformance.com/Cobalt...d4f2a71e234d66 Does and not replace my fuel pump if it is all agreed that the walbro is pointless
Old Jan 15, 2009 | 01:30 AM
  #111
Zooomer's Avatar
Supporting Vendor
The return style fuel system is pointless for your car as well. you don't make enough boost to get into boost referenced mode. You really wouldn't want to, or at least need to, have FP change with boost all the time. so I see it as extra time, money and less reliability for no gains. (unless you're going turbo soon and then i would do the fuel upgrade at that time) And your post shows what I've been fearing with the talk of return style fuel systems. It's not a good thing for people to be thinking about changing their fuel pumps or talking about return style fuel systems when they are totally unneeded. (although the FP in the 05 is a little smaller. still it's plenty for the M62)
A full on return fuel system heats the fuel more than the factory setup and may not filter the fuel as well. Granted we're talking small differences here but there are pros and cons to be considered.
Old Jan 15, 2009 | 01:56 AM
  #112
restonSS's Avatar
yeahhhh, manifoldsssss
I have an idea, whoever can give me the best price on thier turbo manifold percentage wise will win this debate? any takers?
Old Jan 15, 2009 | 03:33 AM
  #113
spike's Avatar
cheap isnt always better.....for what u want look long term(air flow)......buy the right thing the first time or u will later
Old Jan 15, 2009 | 09:37 AM
  #114
Matt M's Avatar
There's one thing I would like to add in response to the people saying that our Walbro flow numbers don't match the ones posted earlier in the thread.
A. The page posted says April 2004.
B. I already stated that Walbro sold their aftermarket pump division and the pumps have since changed.
Old Jan 15, 2009 | 10:09 AM
  #115
djt81185's Avatar
This may be hard to believe but there are people on this site who are actual engineers not engineer type technical people. Off the top of my head there is a mechanical engineer with experience in powertrain design and testing for OEMs and a former mechanical engineer that is now an industrial engineer with a stats minor with oem powertrain and nvh testing and design experience.
Old Jan 15, 2009 | 10:27 AM
  #116
qwikredline's Avatar
the entire thread from Zoomer is demeaning to all the forum members, and his factual inaccuracies about most anything technical are truly scary. I think the ZZP motto should be "go broke...not fast."
Old Jan 15, 2009 | 10:37 AM
  #117
Matt M's Avatar
You quoted Zoom, but must have missed the part where he mentioned "a good majority of the educated people..."
I would like to see you post some of these instances of his "factual inaccuracies." I bet you won't actually find any.
Old Jan 15, 2009 | 11:09 AM
  #118
Witt's Avatar
We can start with this one if you want.
Old Jan 15, 2009 | 11:23 AM
  #119
djt81185's Avatar
What are you trying to imply here?
Old Jan 15, 2009 | 11:31 AM
  #120
and we can add this. Really your treatment and characterization of forum members as idiots is not smart. You want to do business with customers you consider to be jackasses?
Quote: the statement
Originally Posted by Turbo Tim
The option B really only is stuff to add fluid capacity to the system, so it wont help a great deal. If you are using our ZZP heat exchanger that already adds a ton of extra capacity to your system. I havent set the price yet, until I have the ordered pieces in stock and ready to ship.
My response
This statement "option B really only is stuff to add fluid capacity to the system, so it wont help a great deal" is categorically untrue. As a vendor you owe this to your customers , you should not make untrue statements. Option B provides a self bleeding capability to the production lamova system, along with a small added capacity, and a dual pass through the laminova instead of 4 pass. This self bleeding capability was an inexpensive and elegant way to fix an issue that GM identified in production and made as an available option for the enthusiast aftermarket.
The issue is entrained air in the coolant inhibiting transfer of induction heat through the laminova cores, causing high inlet temperatures which causes loss of power...
Old Jan 15, 2009 | 11:32 AM
  #121
Zooomer's Avatar
Supporting Vendor
http://findarticles.com/p/articles/m...10/ai_n9426858
My post was based on the filter being located outside of the tank and fuel passing through it at full speed constantly. In the above article you can read about the pros cons and differences based on filter location. I grabbed my info from there and made two additional comments. 1 was that the differences would be small, 2 I used the word may. If you have proof that the return system will increase filtering or make no difference post it up. I have provided my source although this attempt to show me as lacking technical knowledge is weak at best...
Old Jan 15, 2009 | 11:34 AM
  #122
06black's Avatar
Originally Posted by restonSS
so which manifold should i go with? LOL im O.K. with zzp manifold but i need to know if zoomer, you actually think a gt35r will clear with a .63 exhaust housing.
i'd put money on you not having a build "big" enough to NEED a 35R, were talking about 82mm comp wheels here, ~600hp..
i'd also sideline into your (or whom ever is doing) tuning ability's, do you have a clue what your in for?
judging by your questions, not at all.
research is your friend, and its key to a successful set up.
also, why run such a larger turbo with such a small ****** hotside? that's asinine!
you've got a 600hp turbine, and a 400hp housing (ok, more then 400, but you get the point)
i'd jump to a small-ish / small-mid-size T4 if you think your gonna push the turbo that hard. (start reading up on AR's, i'm not giving them to you)
also, as to the point of this thread, i'd stay away from ANY log manifold. once again, if you think your gonna push a turbo of that size hard enough to need it, a solid equal length manifold(with a rotated flange) is your key to making responsive HP.
don't think that you'll see happy responsive big numbers on a log manifold, as big restrictions inherent to that design cause delayed shaft response (spool per say) and add back pressure (thus lowering HP potential).
Old Jan 15, 2009 | 11:37 AM
  #123
06blackg85ss's Avatar
oh god, it's fun watching the hole get deeper.
Old Jan 15, 2009 | 11:39 AM
  #124
Witt's Avatar
My post was based on the filter being located outside of the tank and fuel passing through it at full speed constantly. In the above article you can read about the pros cons and differences based on filter location. I grabbed my info from there and made two additional comments. 1 was that the differences would be small, 2 I used the word may. If you have proof that the return system will increase filtering or make no difference post it up. I have provided my source although this attempt to show me as lacking technical knowledge it weak at best...
My source would happen to be the car.
All fuel output from the fuel pump is filtered as a returnless. This doesn't change in a return style setup. What does change is the pressure at what the output is being run at and where its being returned. Since the majority of the time, the car is not under boost, pressure will be lower than the 4 bar constant stock pressure. Lower pressure = more volumetric flow from the pump which equals a higher volume of fuel being filtered in a return style setup the majority of the time.
Your initial claim and link to some e article that is not about this specific setup is weak at best.
Wanna keep diggin?
Old Jan 15, 2009 | 11:46 AM
  #125
06black's Avatar
Wanna keep diggin?
****** funny.
