tvs dyno results
well im putting on a 75mm pulley i just put the spec 3 plus clutch and flywheel in .i hope that helps . I think the pulley will be worth 9 whp and the spec lightweight flywheel i hope it will free up 2 whp. so we will see.and i think ill gain around 10 wtq as well hopefully
Last edited by scott allen; Jun 9, 2009 at 06:52 PM. Reason: Automerged Doublepost
I have actually calculated the difference and my local Mustang dyno rates 13% lower than the local Dynojet I have also run on. It certainly would have laid over 300whp on the Dynojet, and I hadn't even sprayed meth/tuned for it at that point either.
Finally, good luck with hitting the 300+whp mark. I will be awaiting the results.
The setup did get fixed and I received all the parts for it, but I never got to run it and do final testing due to my motor blowing up, so I had to sell it to someone else. Full scale production probably never would have occured though due to the TVS's release since it was a direct bolt on affair compared to having to use adapter plates and whatnot.
To me, you shouldnt have to add in a percentage to get to where you want.
Id rather have the paper that says 300, than "well it says 290-something, but just add 11% and its over 300!"...
well if i was on a dyno jet thats what it would of put down. I dont see you dyno jet guys taking away 11%. If you all did no one would have 300 or better whp. I look at a lot of dyno # s on here and 90% of them are dynojets. Lets see someone put down 290 whp on a mustang dyno and that was only about a hour s worth of tuning.
i understand were you comeing from im not bashing either .Im just saying if some one made let say 305 whp on a dynojet that would only be 271 whp on a mustang dyno i dont see the dynojet guys taking away 11%. All im saying is if i was on a dynojet i would put down 322whp.
yea me to im going back to the dyno, this time ill have a light weight flywheel and clutch, and a 75 mm pulley,and more tunning. I hope i can squeez another 10 whp and 15wtq. next month ill will have meth.i hope to get another 15 whp out of that.
You guys should just be happy with what you have. I don't know about you guys but my TVS LSJ has a ton of power. I put down 287whp on a dynojet and I am not going to cry about it.
I am running the stock TVS pulley 3.15" and made probably +70whp over an M62 with the same size pulley.
^ this.
I made sure to get a baseline dyno on GM S3 so that when I go TVS I will know exactly how much I gained as compared to MYSELF on the same dyno with similar weather conditions.
I wouldn't sweat the numbers Scott. If there is truly more to be had with your current mods then just keep at it and you'll get there.
well i got my charts i cant find the last pull we did with the 290 whp and 250 wht. But here is what i do have.
283.9 @ 6750 whp
244.7 @ 5250 wtq
heres another pull
287 @ 7037whp
246 @ cant read the rpms wtq
the 290whp was at 7100
283.9 @ 6750 whp
244.7 @ 5250 wtq
heres another pull
287 @ 7037whp
Last edited by scott allen; Jun 10, 2009 at 01:17 PM. Reason: Automerged Doublepost
i know that im just saying if both dynos were set up right the dynojet would read higher. Thats all im saying.
Last edited by scott allen; Jun 10, 2009 at 06:36 PM. Reason: Automerged Doublepost
bull **** on that , god you guys really need to learn something about dyno's. I have both dyno's at my disposal and guess what, you are wrong sir!!! The dyno jet will not read higher END
