upgraded intercooler pump
Old Apr 25, 2010 | 09:40 AM
scotch89's Avatar
i know theres so many threads about these pumps. but is there an upgraded one out for us guys?
Old Apr 25, 2010 | 09:49 AM
selfinfliction's Avatar
factory one works fine
when it wears out, replace it.
don't 65 components on your cooling system and it will last longer.
Old Apr 25, 2010 | 09:56 AM
scotch89's Avatar
that last sentence u have dosent make sense?!?!?
Old Apr 25, 2010 | 10:06 AM
extra coolers, option b puts more strain on the pump
Old Apr 25, 2010 | 10:08 AM
scotch89's Avatar
o ya i see what your saying lol
Old May 25, 2010 | 01:03 PM
phatnackySS's Avatar
I know this is old but i cant let it slide.
Pump failure is not caused by strain on the pump.
The brushes in the pump motor ware out,
though the pump will start to work intermittently long before the brushes are bad,This is becasue of the carbon dust(from the carbon brushes) will cake up inside the motor and keep the brushes from moving inside the guides, thus keeping the brushes from making contact with the commutator.A tap on the back on the motor will jar the brushes loose and the motor will work for a while before it gets clogged again.
Old May 25, 2010 | 01:24 PM
Pyros777's Avatar
If you buy another pump, you might want to rebuild your old one and start a rotation for when your new pump kicks the bucket.
Here are a couple great how-to's on rebuilding the pump (replacing brushes):
https://www.cobaltss.net/forums/how-guide-43/how-rebuild-ic-pump-199097/
http://www.nloc.net/vbforum/how-arti...-6-00-fix.html
Old May 25, 2010 | 02:42 PM
https://www.cobaltss.net/forums/showthread.php?t=199097
good call. the stock IC pump really is the best for the job. ZZP confirmed it.
The meziere wp136s is the next best thing.
ZZP Test
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
dieGone
Oct 1, 2015 06:27 PM
