Upgrading my cobalt; concerns and advice
Old Apr 29, 2010 | 12:59 PM
vahdyx's Avatar
Okay,
I'm new to the cobalt world and I'm also new here.
From what I understand, doing anything to your car; Intake, Exhaust, Headers can cause errors and check engine light. Is this true? I do want to get a CAI, GMPP Exhaust, and Headers after I get the GM Stage II, heat exchanger and a Torque Damper, but I don't want a check engine light. What's the way to solve this issue.
Also when I get the Stage II can I add a smaller pulley later on and better injectors without a re-tune or will this cause an error as well? If I do choose to do this, can my local shop retune it or should I just buy the OTTP Kit with PCM replacement instead?
Last but not least, Where can I go from here? My goal is 300hp/320lbs of torque. How else can I achieve this?
Thanks
Old Apr 29, 2010 | 01:09 PM
Billig ss/sc's Avatar
If you get the Stage 2 and change anything, I'd retune it. The GMS2 tune is very conservative as it is. And a new pulley might mess with it a little bit, but if you added new (bigger) injectors, you'll completely f-up the tune. If I were you I'd probably go with the OTTP kit and then have someone local to you tune it, it'll be a lot better than a canned tune.
And 300whp from the stock M62 blower will only happen with either NOZZZ or a ported head. And 320wtq is turbo numbers haha. I have 303whp with 265wtq. If torque is your goal, then turbo is the way to go.
Oh and as far as the CEL goes, I've had one on for 2 years and I just got used to it I've tried to have it turned off with HP Tuners which usually works but apparently my car just hates me.
Old Apr 29, 2010 | 01:13 PM
06G85's Avatar
CAI, GMPP Exhaust, and Headers Torque Damper will not cause a CEL.
If one comes on after you put exhaust on, just unplug the battery for 10 minutes and it should go away.
Put an Injen CAI on mine and never got a CEL.
Old Apr 29, 2010 | 01:34 PM
Pyros777's Avatar
Yeah any CEL you throw because of those parts will probably just be a lean code. Do like 06G85 said and also drive around for a while. Your fuel trims will eventually learn out and the CEL will go away. A retune will help make the most of your parts of course.
Old Apr 29, 2010 | 01:51 PM
Greased's Avatar
Thanks
that is kinda of a wierd zone right there since 280 ish is kinda the accepted max of most m62 and a good tvs will put down 330+hp and around 300 tq, and getting a turbo kit for those numbers would be a waste of money.
Stage 2 is overly expensive and most people end up pulleying down anyways and GM stage 2 is a horrible place to start because you have to swap injectors anyways.
A common build for most people is
dual pass with option B
Aftermarket heat exchanger (go with OTTP/ZZP)
2.8 pulley (and required pulley system like belts and tensioner pulley)
spark plugs
80 pound injectors if you can run e-85 and have access to HP-tuners
60 pound injectors if no e-85 available
meth in the case you don't have e-85 (tuning necessary)
3 inch intake
longtube / midlength header downpipe combo (OTTP if you got cash otherwise ZZP)
2.5/3 inch catback hahn is said to sound pretty good
IF tuning is not available for you try getting OTTP will send you a tuned PCM
ALSO DO NOT GET TORQUE DAMPENER. Everyone that gets this than switches to OTTP/TTR's rotated mounts.
Old Apr 29, 2010 | 03:40 PM
vahdyx's Avatar
Okay maybe I was a bit over enthusiastic with my numbers, with my limited car knowledge I guess I want more power with little work. I just wanna put something on tune it and go. I'd have to pay a shop to do everything because I don't have the skills to do it myself.
From what I'm getting from your post is that it's probably better for me to start with a OTTP Stage II instead of a GM then go for exhaust intake etc.
You stated that GM Stage II is a waste, but I found it online for only $560 and Labor for only $250, however the OTTP kit is $580 and Labor is $750 because a dealership won't do it and they won't relearn the crank. So I'm reluctant to get the OTTP kit.
Old May 12, 2010 | 05:59 PM
blake05SS's Avatar
maybe you should just get a mini van
Old May 12, 2010 | 06:14 PM
BlackBaltSw's Avatar
Sell the cobalt and get a GEO metro, way faster and easier to Mod.
Old May 12, 2010 | 07:03 PM
Bootz's Avatar
wow last 2 posts.. very constructive
Old May 12, 2010 | 07:19 PM
blake05SS's Avatar
i know right but i mean cmon lol
Old May 12, 2010 | 07:45 PM
Man i always try to be helpful, but when it comes to properly modding cars theres no easy or quick ass way to do it. Sell it and buy something faster.
Old May 12, 2010 | 08:00 PM
soundjunky's Avatar
how does the saying go?
you can have only two of the following three:
-cheap
-fast
-reliable
reliable power takes money plain and simple.
Were I in your shoes I'd do all GM stage kits;
http://en.wikipedia.org/wiki/Cobalt_ss#SS_Supercharged
I love how you guys (SS/SC) can set your own rev limit and already have a built in nitrous injection button after Stage III.
Old May 12, 2010 | 08:03 PM
blake05SS's Avatar
im all for helping ppl to but i mean for ppl that are completly clueless i mean cmon do some research first
Old May 12, 2010 | 08:21 PM
Caivn's Avatar
direct quote from wiki "LSD was optional for 2005 models (performance package came with LSD) and was standard in 2006 + models." WTF????
Old May 12, 2010 | 08:25 PM
blake05SS's Avatar
idk i dont have the lsd i jacked up the front of my car and my tires spin the opposite way but doing a burnout both tires spin so its not really that big of a deal is it well for drag racing anyway
Old May 12, 2010 | 08:38 PM
soundjunky's Avatar
I have read one then the other;
I have seen 2007 models w/o G85
IMHO, that is really "small fries"...
To clarify, 'G85' is the option for the LSD;
with the supercharged cars the G85 option included the Recaro seats;
Your cars option codes can be viewed on a sticker that will be affixed to your cars sheet metal in the ruck - you need to lift the rear carpet/tire cover, and look for it (production line workers slap it on, so they are not all in the exact same spot).
Your experience is nothing new, non-LSD cars will still spin both tires ~ just not the same as a true Limited Slip Differential... sorry if that makes no sense.
Old May 12, 2010 | 08:42 PM
blake05SS's Avatar
well what is the benefit of lsd besides going around corners if a non lsd will spin both tires
Old May 12, 2010 | 08:56 PM
Chevycobaltss3's Avatar
I have LSD and I can care leas if my car flips going around a tight corner! Lol I'm just tired of all the cobalt breakdowns. Like it said up top. U can only pick two. I guess I picked fast and cheap lol but not really. It was breaking down the first day I drove it off the lot. Damn u gm
Old May 12, 2010 | 09:42 PM
soundjunky's Avatar
it's not hte same;
in one instance it's more of a passive spinning and the drive power is only being transfered to one axle, while with the LSD the drive power is being put to both axles (more or less, is the Quaif/Torsen style LSD - that requires more research to understand).
Then again, I attempted to bring this thread back on topic for vahdyx;
if you want to debate the usefulness of LSD, why not find/make another thread and find someone who can better explain it for you (because I sometimes suck at explaining).
Turbo Johnny
Feb 21, 2019 09:41 AM
jthwjde
Sep 7, 2015 09:24 AM
medic710
Sep 6, 2015 08:53 PM
SS_2009_TC
Sep 4, 2015 10:48 AM
NoBalt123
Sep 4, 2015 07:10 AM
