Valve spring install
Old Jul 9, 2010 | 06:31 PM
Perfect.disguise's Avatar
Hey, how much have you guys been charged for having valve springs and or neutral balance shafts installed? Searched everywhere for a how to, is it that hard of a job?
Old Jul 9, 2010 | 09:44 PM
hawkesb3's Avatar
if ur guna have neutral balance shafts put in you might as well build the motor lol springs you can do yourself hella easy
Old Jul 10, 2010 | 12:29 AM
mrbelvedere's Avatar
its all easey to do
Old Jul 10, 2010 | 12:47 AM
exiged's Avatar
Prolly around ~$400 to install springs
Old Jul 10, 2010 | 08:03 AM
oldskool's Avatar
Your gonna pay quite a bit for the balance shaft install in terms of hours. I know on the J-body, there is not enough room between the frame rail and the engine to get them out, hence the engine must be dropped/removed. Even if you can do it in the car, you still have to the water pump chain in a very tight space.
That said, if you have a shop manual and are mechanically inclined, or someone who knows how or has done it before to help, you can save some serious money.
Old Jul 10, 2010 | 08:41 AM
Frew's Avatar
there is enough room to put the balancing shafts in with the motor in the car, just gotta be creative. The valve springs are cake, just time comsuming. Make sure you get the correct valve spring compressor.
turbochargedss2012
Sep 20, 2023 12:17 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
Trav3480
Sep 28, 2015 02:46 PM
