valve spring install
Old Oct 2, 2010 | 11:35 AM
cli3e0339384398jk's Avatar
anyone done them here without removing the head? if so please chime in with what tools you used ( just wondering if any specialty tools are needed)
Old Oct 2, 2010 | 08:11 PM
mrbelvedere's Avatar
you need a overhead valve spring remove install tool and the fiting to screw in the head for an air hose to hook up to
Old Oct 2, 2010 | 08:18 PM
lsjion's Avatar
check out the lsj buildbook, its a goodson piece. but honestly, have fun doing so. I pull these apart and install all the time since i port them, the hard part is putting the keepers on, since they are so tiny and space is limited.
Old Oct 2, 2010 | 09:30 PM
chevysssc's Avatar
x2 its not for the novice
Old Oct 3, 2010 | 12:36 AM
insylem's Avatar
In A&P school (Aircraft Mechanic School) The instructor showed us how to replace a valve spring on an O-470 (Horozontal Opposed, 470CU Aircraft Engine) and I know car engines are VERY diffrent but the main principals are still the same so I dont see why this trick would NOT work on an LSJ.
Get a nylon rope with no frays on it.
Make sure the cylinder that your changeing the springs on is on compression stroke,
Remove the spark plug, and feed the rope into the cylinder then rotate the engine slowly
on compression, this will push the rope up against the inside of the valve face holding it closed
and keeping it from falling into the cylinder.
Then swap out the valve spring
Then rotate the engine backwards to take the pressure off and remove the rope.
-Jonathan
Old Oct 3, 2010 | 09:12 AM
-Jonathan
ive done small block mopars tha way works great a&p school sucks
Old Oct 3, 2010 | 01:43 PM
thanks everyone, thats what i thought just wanted to confirm
Old Oct 3, 2010 | 05:31 PM
you can do it if you take your time
Old Oct 3, 2010 | 05:37 PM
ecot3c inside's Avatar
or you can put a socket over it and hammer it good once and catch the valve before it falls and catch the spring retainers with your teeth... talent right there
putting the new ones on are going to be tough.
Old Oct 3, 2010 | 06:21 PM
chevysssc's Avatar
^might need to pic up a pro with their mouth, u can find them in the city on corners.
Old Oct 3, 2010 | 06:23 PM
^ not many pro's on city corners these days..
actually scratch that. unemployment ftw!!
Last edited by ecot3c inside; Oct 3, 2010 at 06:23 PM. Reason: Automerged Doublepost
Old Oct 3, 2010 | 08:42 PM
SunburstSS's Avatar
i think zzp sells a tool to remove the valve springs without removing the head, can anybody confirm this ?
Old Oct 3, 2010 | 10:15 PM
cant see anything on there site
Old Oct 4, 2010 | 09:48 PM
SunburstSS's Avatar
i think i've a post by zoomer about that somewhere...u can try to contact zzp they might have it, just email them i guess..
Old Oct 4, 2010 | 10:03 PM
yah i have emailed them, looking forward to doing the internals this winter on this motor
Old Oct 4, 2010 | 10:20 PM
lsjion's Avatar
if that's the case, just wait till you have it all apart, it'll be less of a headache
Old Oct 4, 2010 | 11:18 PM
yah i think im going to just wait and when i send my head in for P+P i will do it then.
Old Oct 4, 2010 | 11:23 PM
lsjion's Avatar
send it to me
Old Oct 4, 2010 | 11:36 PM
send it to me
how much and what do you do? ( how much increases flow, etc)
Old Oct 5, 2010 | 12:53 AM
insylem's Avatar
come to think of it, since this is an interferance engine,
If you put the piston on TDC on compression the valve wont be able to fall all the way into the cylinder before resting on the piston. Dont know if it will be high enough to grab or not though
turbochargedss2012
Sep 20, 2023 12:17 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
Trav3480
Sep 28, 2015 02:46 PM
