Valve Spring specs needed.
Old Apr 3, 2006 | 11:01 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Question Valve Spring specs needed.
I am trying to get all the parts ordered for the 300+hp Build now that I will have stage 2 shortly. The problem is that I need to know the outside\inside diameter and seat\open pressure of our stock valve springs. I have found the cam used in the build but for some unknown reason there is no cross reference to the springs\retainers that would match up for our valve train. If someone knows the answer I would really appreciate you letting me know. Thanks.
Old Apr 3, 2006 | 11:23 PM
Bump.
I need help please.
Old Apr 4, 2006 | 12:43 AM
Halfcent's Avatar
I'm old school
I don't have the answers. But you can probably call Ferrea and ask them. They already have a product for the L61 engine, but not for the LSJ. They might be able to find out for you better then anyone.
Old Apr 4, 2006 | 12:53 AM
Thanks, I will call in the morning.
Old Apr 4, 2006 | 01:09 AM
my_bd's Avatar
you should pm Sinister Redlines or WopOnTour
they know all that stuff....
Old Apr 4, 2006 | 03:05 AM
WopOnTour's Avatar
All I can give you tonight is the spring seat pressure spec, the dimensions I'll have to get you tommorrow
Valve Spring Load Valve Closed @32.5 mm - 271.0 Newton (61.1lbs) minimum 245 N (55.1lbs)
Valve Spring Load Valve Open @22.5 mm - 575.0 Newton (129.5lb) minimum 525 N (118.2lbs)
The OPEN spec is at 10mm valve lift
HTH
WopOnTour
Old Apr 4, 2006 | 05:53 AM
NJHK's Avatar
Do you plan on revving higher than your limiter?
Also, does anyone know what is the highest RPM the M62 can spin up to without heatsoaking real bad and still generate power? Just curious.
Old Apr 4, 2006 | 09:04 AM
HTH
WopOnTour
Thanks WOP, your time is appreciated as always
I am planning on raising the RPM considerably once the PCM is cracked. In the 300+hp build the dyno chart shows redline at 7850.
Old Apr 4, 2006 | 10:11 AM
Halfcent's Avatar
I'm old school
Here's what I've learned about increases the RPM limit so far.
Ferrea springs without the optional valve seat are usable on the street and safe up to 8000 RPM. With the optional seat, they are not streetable, and can run to over 10000 RPM. There is some question as the ability of the stock hydraulic lifters maximum RPM. Bates engineering makes a solid lifter that is safe to over 10000 RPM, but makes for a non-daily drivable car (solid lifters driven daily will wear out your cams)
In discussing the benefits of increased RPM with many pros, the horsepower will increase, but the torque will start to drop. Plus, for every increase in RPM, the bearing load increases 4 fold, so reliability starts to drop as well.
turbochargedss2012
Sep 20, 2023 12:17 PM
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Trav3480
Sep 28, 2015 02:46 PM
