Vibrant Catback Install Question
Old Apr 18, 2008 | 10:03 AM
QuikSilverSS's Avatar
I have a buddy that just got his 3" Vibrant Catback today and we want to install this tonight. I have heard that the Vibrant exhaust you need to drop the rear suspension to get it over the axle to fit in? I have the GMPP Catback and it came in 3 pieces and was simple to install even with just jack stands, can someone who has this system shed some light on this??
Old Apr 18, 2008 | 10:25 AM
DoMiStIc_RuSh_06's Avatar
Is it one piece, or 2 or 3. If its only on piece, you will have to either drop the rear suspension or cut it in one spot....If your lucky, with the car totally jacked up and try to fit it thru, but i doubt it will happen...
Old Apr 18, 2008 | 10:35 AM
Its a 2 piece design, hopefully just a bolt on simple exhaust swap! like my GMPP catback was
Anyone else with this exhaust can you chime in????
Old Apr 18, 2008 | 10:43 AM
Zekdemos's Avatar
All i can say is i hope we dont have to drop the rear
Old Apr 18, 2008 | 10:44 AM
JohnnySasakiMGS's Avatar
**** that **** just send it back if thats the case.
Old Apr 18, 2008 | 10:45 AM
D4u2s0t's Avatar
why not? all you do is take off the wheels, and take off ONE strut bolt on each side (the lower one). then the whole thing will come down. if it's in 2 pieces, that should give you more than enough clearance.
if you have no idea at all how to drop the rear suspension, and don't know anything about cars, and have zero mechanical knowledge, it shouldn't take more than 3 or 4 minutes to take those 2 bolts off. if you have a basic understanding of what a strut bolt is, it will take less time.
Old Apr 18, 2008 | 10:47 AM
Zekdemos's Avatar
i dont mind playing with it but i know my luck and its never good lol
Old Apr 18, 2008 | 10:49 AM
ya i know its not hard to do, just wondering how heavy that suspension is going to be, dont want to drop a couple hundred pounds of hanging suspension on either of us, the GMPP was easy to do, cut the stock exhaustjust before the axle and the new one fit in no problems
Old Apr 18, 2008 | 10:55 AM
D4u2s0t's Avatar
it's still connected in other places, so you don't have to catch anything. put a jack under it, let it sit on the jack, take off the 2 bolts, and lower the jack.
the gmpp is also 3/4" smaller though. who knows, you may not even need to lower anything.
Old Apr 18, 2008 | 10:56 AM
Zekdemos's Avatar
is it 5pm yet lol
Old Apr 18, 2008 | 01:35 PM
Old Apr 18, 2008 | 01:41 PM
RA071623's Avatar
I did mine last weekend. Here is the thing I found it hard on Jack Stands to get the long pipe over the rear support beam so I took the one bolt out of the Control Army Bushing and lowered the control arm down just enough so that I could fit the flange over the rear axle type thing. Make sure you can raise the CAB back up so that the bolt lines up with the holes on both sides. I believe the bolt is 15 mm and the nut was 18mm but don't quote me on that. It just takes a little elbow grease. The exhaust is really deep though. Hope this helps.
Old Apr 18, 2008 | 01:43 PM
D4u2s0t's Avatar
you already have the answer, and i told you how to disconnect the rear if you have to. what is left to bump
Old Apr 18, 2008 | 01:44 PM
WSFrazier's Avatar
I've installed 2 Vibrant 3" catbacks on jackstands and didn't need to drop the rear.
Old Apr 18, 2008 | 02:22 PM
bluecobaltss06's Avatar
Yeah I didn't even touch the rear on mine. It fits right in with just the cutting of the old exhaust.
Old Apr 18, 2008 | 03:30 PM
Thanks guys ! appreciate the help
Old Apr 18, 2008 | 06:46 PM
dannysauer's Avatar
just have to jack it up all the way but it will fit
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Bohb
Sep 27, 2015 09:11 PM
