Wanting to run bigger injectors
I am wanting to install bigger injectors to help with my newly installed Meth/Alcohol/H2O injection so that I dont end up with a lean condition.
I am on the stock pulley and I will be getting a full dyno tune within a couple of weeks.
So I am wondering what size should I shoot for? I was thinking maybe 42.5s or 45s because I think 60s would be way over kill
anyways, all informative input will b appreciated
ok, i plan on revving higher, probably move the rev limiter up a little bit about 7200, alot like ur current set up ralliartist
I do not intend to change pulley size, I am going to switch the car over to turbo, im currently saving for the Hahn kit, I just want a lil more go and a lil more insurance until I can park the car and do the swap
Quicksilverss has meth and told me that it richened him out by 0.5 to 1.0 afr. Tuning for meth you have to lean out your tune. If your leaning out your tune and therefore squirting in less fuel, wouldnt that would bring your idc's down slightly and actually help you not need bigger injectors.
I wouldn't worry about injectors. Spray the meth, get tuned. You should be fine.
the only reason I got injectors, was because I didn't have the meth yet.
Last edited by ralliartist; Jul 11, 2008 at 07:02 PM. Reason: Automerged Doublepost
soccerkid13
Jan 11, 2016 10:25 AM
jcalvin1126
Sep 11, 2015 10:24 AM
Macgyver2484
Sep 2, 2015 05:44 PM
