Wanting to run bigger injectors
Old Jul 11, 2008 | 06:47 PM
BlkWdoSS's Avatar
I am wanting to install bigger injectors to help with my newly installed Meth/Alcohol/H2O injection so that I dont end up with a lean condition.
I am on the stock pulley and I will be getting a full dyno tune within a couple of weeks.
So I am wondering what size should I shoot for? I was thinking maybe 42.5s or 45s because I think 60s would be way over kill
anyways, all informative input will b appreciated
Old Jul 11, 2008 | 06:48 PM
an0malous's Avatar
what pully are you (or intending to) using?
Old Jul 11, 2008 | 06:49 PM
ralliartist's Avatar
42lbs will work just fine. But now that you have meth injection, you don't really need bigger injectors unless you pulley down or rev really high.
Old Jul 11, 2008 | 07:00 PM
BlkWdoSS's Avatar
ok, i plan on revving higher, probably move the rev limiter up a little bit about 7200, alot like ur current set up ralliartist
I do not intend to change pulley size, I am going to switch the car over to turbo, im currently saving for the Hahn kit, I just want a lil more go and a lil more insurance until I can park the car and do the swap
Old Jul 11, 2008 | 07:01 PM
MidnightNB's Avatar
Quicksilverss has meth and told me that it richened him out by 0.5 to 1.0 afr. Tuning for meth you have to lean out your tune. If your leaning out your tune and therefore squirting in less fuel, wouldnt that would bring your idc's down slightly and actually help you not need bigger injectors.
Old Jul 11, 2008 | 07:02 PM
an0malous's Avatar
if your not changing pullies you dont need injectors.
especially with meth
(meth acts as an additive fuel, thereby actually makin your injectors work LESS)
I wouldn't worry about injectors. Spray the meth, get tuned. You should be fine.
the only reason I got injectors, was because I didn't have the meth yet.
Last edited by ralliartist; Jul 11, 2008 at 07:02 PM. Reason: Automerged Doublepost
Old Jul 11, 2008 | 07:25 PM
BlkWdoSS's Avatar
Ok, then that is what I will do, thanx for all of the advise guys, it is greatly appreciated
soccerkid13
Jan 11, 2016 10:25 AM
chefhhr
Oct 26, 2015 10:36 PM
jcalvin1126
Sep 11, 2015 10:24 AM
medic710
Sep 6, 2015 08:53 PM
Macgyver2484
Sep 2, 2015 05:44 PM
