water meth kit installed, question
Well unhooked the ground and am driving it seeing if it goes back to normal but it seems to still be bogging a bit, i think i have a boost leak somewhere beacause my afr is going from 14-16 at idle
It is completely normal for your AFRs to jump around on idle and even when driving, what is your vacuum at idle ?
so long as the experts are in here...
if i'm running all cooling mods on a 2.8, what size nozzle could/should i run? i'm currently on a 5gph, but wondering if it would be worth going higher, like to an 8 or if the difference would be negligable
Lol wtf! I unhook the ground, why is the thing still spitting water, i had half a tank when i left and came back after abunch of pulls and had it at almost empty, i pulled the black fuse thing apart maybe that will stop it
water
if you don't have a check valve in the water line while your under vacume it will suck through the pump..
