week one with cams
Rent me! per hour
week one with cams
after 2k miles on them so far. i will say that this thing is a freakin animal above 5k all the way to 7700 rpms. bottom end seems a bit softer now, this i can live with.
idle. well. i have hidden most of the cam sound to try and keep the car low key. to a degree at least. timing works wonders
the grind is the 272. supertech 78lb springs. the usual stuff that goes along with this.
first issues with tuning. well, where to begin with this one. my car, acts like no one else's. which inturn means no one else's camfiles work worth a **** in my car. strike one.
major work had to be done in the timing departments to get the car to idle good, not surge, or anything stupid.
07's have a larger range of "free will" so to speak when going through random bits of the maps in general. one has to work with this, then pull hair out. spend 5 hours in the driveway working on low speed coastdown, idle, other fun things.
in the end, im extremely happy with the cams. the way they perform, and the unholy power surge at 5k.
if you know to tune, and are good with timing. get em. get the valve train as well. set your rev limit to 7800 and smile the entire time
Rent me! per hour
i didn't install them. they are the same regrinds witt/djt are running. the 272's flowtechnicsonline i think is the place i got them done at. dave is a nice guy. doesn't always answer the phone, but will get back with you.
something about the 07's p32 makes the car a bitch to work with.
ghaaaaaaaaaaa.
most of the people at the chicago meet didn't know i had cams in the car just by listening to it
supertech 78 dual springs. Ti retainers. seat locators. 272 cams
ghaaaaaaaaaaa.
Glad to see that they have worked out for you. I knew that had to be what you were doing when you kept complaining the car wasn't running right and whatnot!
Congrats!
Did you pull the cylinder head to do the valvetrain, or did you just do it while attached to the block? Just curious? Also, did you do neutral balance shafts as well? Thanks.
Rent me! per hour
bottom end is stock still.
i spent about a grand on everything. between cam cores. shipping, gasket kits and other misc crap here and there
you can do the cam/spring swap with the head still on it. just need 100-110 psi cylinder pressure to keep the valves up.
remember kids. stay in the lines when working with the coloring book
Original Hayden Fanatic
I KNEW IT!!! lol
Your car takes off like a ******* bat outta hell at 5K, I saw you 1 time during the cruise when you got on it...
You did a great job hiding it, but something just sounded a bit off that made me wonder, hmmm...
Rent me! per hour
im sneaky. 90% of the people there didn't know it was cammed. if you caught the car when it was cold. it was a dead give away.
i even dropped the idle to 850 and it didn't change much. so far im very pleased with the outcome. not happy with the way i had to tune it to get the car to idle right, then again hpt fucked us on the limited tables
lol not a bad idea, if someone has wireless down there, I'll hook one up to my laptop on a continous live feed. I'm sure it will be entertaining....... working on cobalts = cuts, cursing and throwing things
Rent me! per hour
That right there is my only lurking issue...
