week one with cams
Old Apr 9, 2008 | 11:25 AM
  #76
Area47's Avatar
Rent me! per hour
no problem.
i can make the car lope hard if needed. it can sustain an idle down to 500 rpm.
  #77
Edubs's Avatar
Originally Posted by Area47
no problem.
I'm at 950 right now...
Old Apr 9, 2008 | 11:30 AM
  #78
widebody_balt_ss's Avatar
Old Apr 9, 2008 | 11:35 AM
  #79
Area47's Avatar
Rent me! per hour
thats where mine sits at. timing control dictates the amount of audible lope
Old Apr 9, 2008 | 11:52 AM
  #80
Z Speed's Avatar
I want my car to lope Im gonna have to get a set of these since I ran out of bolt on parts lol
Old Apr 9, 2008 | 12:41 PM
  #81
06black's Avatar
you can start to feel the cams come in at 4k. really come in at 5k. then go smashing into the limiter.
bryan. wek sos
the only time you will hear the cams in my car is when the afr drops below 16.5. any richer than this. it's smooth as silk. still pulls an indicated 17.75 inhg
they do just fine for daily driving. no issues thus far.
im pulling the valve cover this weekend to check the wear
Free stuff bitch.
i bet my car pulls harder!
you find that pyro gage? i'm gonna have **** apart this weekend, perfect time for a little install!
thanks pookie!
biscuits and gravy.
Old Apr 9, 2008 | 12:58 PM
  #82
Area47's Avatar
Rent me! per hour
ahhhhhhhh flash backs of high school. b&g for b-fast
the egt is in my garage, in a box. sitting ontop of a set of carbs and a head for my 240z
free always kicks ass
Old Apr 9, 2008 | 01:02 PM
  #83
06blackg85ss's Avatar
damnit I want some free stuff..
someone toss me an egt gauge, I really really need one
Old Apr 9, 2008 | 01:03 PM
  #84
06black's Avatar
F-off paul!!!
lol, jk.
its mine!
you get the MAF config working bro? (paul)
Old Apr 9, 2008 | 01:05 PM
  #85
sorta, still can' get the AEM to log correctly.
but damn those 79lb injectors made the world of difference in driveability.
still getting some wack ass IDC spikes in PE though, but now at least it holds an 11.4 afr across the board.
Having issues now with 4th gear, seems like the car is bogging out real bad, but it's still at the correct AFR. gonna get some runs in tonight and I'll send you the logs if you want to check em out
Old Apr 9, 2008 | 01:06 PM
  #86
06black's Avatar
4th gear!!!!
blah!
i'm pushing wayyyyyyyyyyyyyyyyyyyyyyyyyyyyy tom much timing to make the car KR free in 4th.
max out 1-3 and you surly wont need 4th!
Old Apr 9, 2008 | 01:20 PM
  #87
Area47's Avatar
Rent me! per hour
zing it to 7500. screw 4th
Old Apr 9, 2008 | 01:29 PM
  #88
spike's Avatar
saved for later
Old Apr 17, 2008 | 12:31 AM
  #89
ralliartist's Avatar
so hows the wear on these regrinds?
Old Apr 17, 2008 | 12:52 AM
  #90
freakta's Avatar
I would love to do
cams I can't wait to see the outcome
Old Apr 17, 2008 | 10:42 AM
  #91
Area47's Avatar
Rent me! per hour
just peachy. pullin the cover off this weekend to check em again. everything so far is wearing just fine.
rolled into the throttle today commin to work messing with a co-worker. afr at 12.2 and 25 degree's of timing.
with the measly stage 2 pulley it will set you in the seat {hush turbo kids}
Old Apr 17, 2008 | 11:15 AM
  #92
REIGN SS's Avatar
Original Hayden Fanatic
So did you buy blanks?
http://www.crateenginedepot.com/stor...-P321C141.aspx
http://www.crateenginedepot.com/stor...-P325C141.aspx
Or something different?
Old Apr 17, 2008 | 11:17 AM
  #93
lsjwannabe's Avatar
something different, those do not work. He got stock cams reground to 272 specs
Old Apr 17, 2008 | 11:36 AM
  #94
Area47's Avatar
Rent me! per hour
stock cores from a reliable person, then sent off to get redone. now i have to recheck everything this weekend
Old Apr 17, 2008 | 11:37 AM
  #95
REIGN SS's Avatar
Know any reliable people?
  #96
06black's Avatar
I'll try to get you that timeing info today bryan.
Old Apr 17, 2008 | 11:38 AM
  #97
Area47's Avatar
Rent me! per hour
you should do that, cause that would rock ass
reign, you don't need cams in your car
Old Apr 17, 2008 | 11:39 AM
  #98
RedBaseBolt's Avatar
Vid / Pic?
Old Apr 17, 2008 | 11:41 AM
  #99
REIGN SS's Avatar
Why do you say that?
I'm asking for a friend currently, Don't know what good LSJ cams would be to me anyways
Old Apr 17, 2008 | 12:53 PM
  #100
Blown 4-banger's Avatar
I know you said I can't, but I'll have my **** idling pretty at 1200 rpm. No need to have it idle any lower than that, plus you get better throttle response with a higher idle.
Yeah, especially considering, the LSJ cams don't fit the L61 head
Last edited by Blown 4-banger; Apr 17, 2008 at 12:53 PM. Reason: Automerged Doublepost
