weekend fun
Old Jul 7, 2008 | 11:59 AM
ralliartist's Avatar
hahahahahahahahah, now it's a funny thread.
an0malous's Avatar
Originally Posted by Area47
hotter flame vs colder intake.
meth itself burns rather warm anyways. we know this. zoomer was actually right on the 50/50 mix part.
in a nutshell. octane. i wasn't going for cooling, i was going for power. water will not produce power in this type of engine. straight methonal will produce way more power than 50/50 anyday of the week. we know this. so why not run straight meth? flash point of 185 degree's. adding water raises the temperature. invisible fire during the day is bad.
im sure there is more to it than that. im just no where near awake enough to think about it right now
yup i agree on straight meth, bad idea....
and i can understand upping your meth content for octane,
which will allow you greater timing....
but what if you dont need more timing?
If Im already at 25* from toe in to redline with 50/50,
and the specific energy of methanol is less than half that of gasoline
what benefit is there to upping my methanol content?
Old Jul 7, 2008 | 12:04 PM
It'll richen you up some more, then you lean it out some more. Therefore more power will be made.
Or, my brain is stupid.
Old Jul 7, 2008 | 12:07 PM
an0malous's Avatar
gasoline has a specific energy of about 43mj/kg,
meth is only about 20mj/kg
so the math says adding meth, and pulling gas, will make less power.
if you need more timing, i completely understand adding more meth.
I imagine with areas cams it completely changes the beast...
but if your already at peak timing, im having trouble seeing the reasoning for upping the concentration?
basically im asking, why would I go to 75/25 myself?
Old Jul 7, 2008 | 12:12 PM
well I know for a fact that this isn't true. Even if the math says so. I don't know if you've ever heard of parish, but he drives a 9sec truck. anyways, point is, he used meth to gain power, lots of power. He actually only made about 600whp on pump gas, on meth, he made about 800, with race gas AND meth, he made over 1000. He got to where he was spraying so much meth that he had to pull fuel from the injectors.
I dunno? You tell me why?
Blown 4-banger's Avatar
Nitromethane has only 1/4 the potential power of gasoline, however it only takes 1/8 as much air to effectively burn the same amount of fuel. Therefore with the same amount of air with both gas and nitro, nitro will produce FOUR TIMES the amount of power gas will. Hence why blown nitro motors make 8000 hp, a comparative gasoline motor would only be making 2000 hp. The stoichiometric air fuel ratio of nitro is 1.7:1, so it burns A **** LOAD of fuel. Methanol is the same way, stoichiometric afr of methanol is 8:1, more fuel burned = more power.
Old Jul 7, 2008 | 12:15 PM
ahhhh, thanks for explaining that. I'm so glad we got nerds on our forum. lol.
Old Jul 7, 2008 | 12:30 PM
an0malous's Avatar
very interesting. i didnt even think of that.
but lets do a little math
14.7/8 = 1.8375
Gasoline needs 1.8375 times more air to combust.
43/20 = 2.15
gasoline generates 2.15 times more energy per unit than methanol...
the numbers are certainly alot closer with that info than i had thought....
but gasoline with enough meth to reach peak timing should still make more power.
than gasoline with a higher concentration of meth than required for peak timing?
Im kinda just winging it here....but does that make sense?
Old Jul 7, 2008 | 12:35 PM
Area47's Avatar
Rent me! per hour
now you're starting to get the idea. the energy of fuel vs the lack of energy in water
parrish's truck never went 9's.
his fairmont does though
Old Jul 7, 2008 | 12:42 PM
an0malous's Avatar
hmm well thats certainly true, water has shown to be an anti detonation factor...
but it certainly isnt going to make any power
hmmm
what kind of difference between 50 and 75, power wise area?
Old Jul 7, 2008 | 01:05 PM
  #36
Basically what I was saying is, just run nitro! Your car will make several thousand hp before literally exploding. Seriously though, it would take like 20, 160 lbs/hr injectors to provide enough fuel. Hell top fuel motors have a total of 42 injectors!!! 10 in the injector cap, 16 in the intake manifold, and 16 in the head itsself! Thats a **** load of fuel, at WOT they consume fuel at a rate of 1 gallon per SECOND!!! With methanol, the 1400 hp ecotecs use 12, 160 lbs/hr injectors.
Old Jul 7, 2008 | 01:14 PM
  #37
Area47's Avatar
Rent me! per hour
i was at 290 at 11.3 afr
then dumped water into the resivoir. leaned it out to 11.8 286.
i made 285-286 4 times in a row
Old Jul 7, 2008 | 01:25 PM
  #38
BlackSS/SC's Avatar
I like this thread
When you made 290hp, was it 100% meth, or 75/25 mix?
Old Jul 7, 2008 | 01:33 PM
  #39
ecotecon18s's Avatar
yeah, but 10.1 on street tires aint bad either...
  #40
06black's Avatar
you won't be running less than stock boost. you're be more efficient in producing power.
eat it turbo boy.
as i recall it took you race gas and a 2.5
:X
my race gas / 2.5 numbers were still better then this.
stock EVERY THING blower boi.
Old Jul 7, 2008 | 01:36 PM
  #41
lsjwannabe's Avatar
I thought bryan had you beat? Well my blower beats all other blowers so
Old Jul 7, 2008 | 01:37 PM
  #42
Area47's Avatar
Rent me! per hour
actually no, you made less. i just posted the street numbers
dingleberry.
black 75/25
Old Jul 7, 2008 | 01:43 PM
  #43
06black's Avatar
you has cam's bitch!
i sent you the flow numbers with stock cam VS AM cam, you know the difference.
douchnozzle.
i will forever and always have him beet.
Turbo>Blower
p.s.-sean you gonna come out to woodward soon?
I need some one intelligent to cruse around with.
Old Jul 7, 2008 | 01:44 PM
  #44
Area47's Avatar
Rent me! per hour
BEAT.
me no care. it took you a 2.5 to do less!
lawl
::puts on gloves::
Old Jul 7, 2008 | 01:46 PM
  #45
06black's Avatar
BEAT.
lawl
::puts on gloves::
i has more torque still....
if you wish we can compare current set ups...........just a thought.
Old Jul 7, 2008 | 01:52 PM
  #46
Area47's Avatar
Rent me! per hour
i has traction.
stock cams = torque
Old Jul 7, 2008 | 01:54 PM
  #47
lsjwannabe's Avatar
douchnozzle.
Turbo>Blower
hopefully so just working on the last few things before i strap it down and give it hell. You still have my number right?
Old Jul 7, 2008 | 01:55 PM
  #48
I has popcorn...this is gettin good...
Old Jul 7, 2008 | 01:57 PM
  #49
an0malous's Avatar
good discussion for sure you learn somethin every day.
looks like its time to go buy some bottles of heet lol.
Old Jul 7, 2008 | 01:59 PM
  #50
Area47's Avatar
Rent me! per hour
just an FYI people. this is street numbers. what i run daily. i don't disclose the dyno numbers. because they are just that. dyno numbers.
