weird idle or misfire kinda sound
Old Oct 14, 2007 | 10:10 PM
FryLoch's Avatar
after my car heats up and I let it sit there and idle it starts to idle kinda weird. Almost like it has a performance cam in it or like it's misfiring everynow and then. Now it could be that I need an oil change im gettin one on wednesday... im about 1000 miles over. But I was wondering if anyone else's car is like this. If maybe it's just the way stage 2 is...?
I have stage 2 the honed manifold and gmpp exhaust. that's it.
also... there was that crinkle on the intake so I thought I would try an pop it out... Well I open it up next to the throttle body and find that the intake has water in it... er... well moisture and dirt looking stuff. is that normal too? I havent driven through any big puddles that I know of...IDK WTF is going on, I have no cels so it cant be too bad...
bumpage... any input?
Old Oct 14, 2007 | 10:14 PM
an0malous's Avatar
with that kinda junk in your intake first thing i would think is your maf is likely dirty.
which would be a good explanation for a rough idle too.
go grab yourself some crc maf cleaner and try that first.
id check your plugs too.
Old Oct 14, 2007 | 10:20 PM
cobaltssTH's Avatar
my car does the same but my RPM's just jump up and down
Old Oct 14, 2007 | 10:24 PM
Beck's Avatar
possible vacuum leak. check your lines
Old Oct 14, 2007 | 10:26 PM
cobaltssTH's Avatar
is it possible to be something wit the tune we did.
Old Oct 14, 2007 | 11:36 PM
stonny9's Avatar
mine sounds like that now and it did it when it was completely stock. If I find the vid of mine i'll post it.
Old Oct 15, 2007 | 12:46 AM
rukkee's Avatar
Mine does the same, It has a ppuft every 5-6 seconds or so . Ive had everything looked at and they say it's fine . I even pulled the injectors and had them cleaned , didn't change anything.
That is prolly some blow by from the crankcase breather that connects to the intake. Alot of people have that .
Old Oct 15, 2007 | 10:56 AM
FryLoch's Avatar
well... if the maf is screwed up it's ok... im puttin a new intake on maybe next week and im taking it in for an oil change on wednesday and I'll have them take a look at it too.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
jimbofug007
Oct 2, 2015 12:06 PM
