Weird Noise
Old Jun 12, 2005 | 02:38 AM
PaulSS's Avatar
Weird Noise
I was messin around with a 300 C today and after about the 3rd full out run.. i started to hear this noise toward the back of the car.. kinda like something was loose.. a tapping noise.. but only when i was off the gas and slowing down.. anyone else have this same problem?..
Old Jun 12, 2005 | 02:48 AM
3fo893013L's Avatar
perhaps exhuat back fire is what you heard? My car if the R's are high and I let go of the accelerator and slow down I hear popping or tapping noises. It seems normal to me. I won't worry to much.
Old Jun 12, 2005 | 07:15 AM
gdavis's Avatar
Have a bad resinator on my SS rattles real bad. GM is re-designing it. Dealer is to replace my exhaust from the cat back as soon as one becomes avalible. sounds like a tin can going down the road.
Old Jun 12, 2005 | 11:11 AM
03SVTF's Avatar
Slipping The Clutch is a bad thing to do, if you dont liek the noise simply let it sit in nuetral and glide down to a slower speed. Not only will you eliminate the noise your clutch will last longer by not "downshifting". I know i use to be the same way with my car, till i found out how bad downshifting reallyl is for a clutch.
Old Jun 12, 2005 | 05:49 PM
Cooked_Electron's Avatar
I hear that noise all the time...it's definitely exhaust afterfire popin' and crackin'. Nothing to worry about.
Old Jun 12, 2005 | 11:59 PM
turboeco's Avatar
If its a tapping noise, Tighten your antenna.
Used to always loosen on my cavalier, seems this is the same.
Old Jun 13, 2005 | 12:24 AM
PaulSS's Avatar
ok.. thank you for all the suggestions.. starting from the latest.. already tightned the attena.. but it is very similar to that noise.. next.. i def know its not the clutch.. when i slow down i usually just throw her into neutral.. and im not talking about at high rpms.. im talking about at low rpms at around 10 mphs.. ( i assume i can hear it more because of the lack of windnoise).. this is why i also rule out backfire.. ud hear that while the rpms were dropping.. the only thing i can think of it being is something loose..
Old Jun 13, 2005 | 12:53 AM
MarcS's Avatar
The Stig
You're supposed to use your gears with a manual tranny Suggesting to coast in neutral is not the correct way to drive this type of car, you will kill your breakes.
Old Jun 13, 2005 | 01:27 AM
b-spot's Avatar
Its called heel-toe and double clutch dude. You get zero transmission wear that way.
Old Jun 13, 2005 | 01:44 AM
MarcS's Avatar
The Stig
http://www.se-r.net/transaxle_clutch/clutch_not_to.html
Old Jun 13, 2005 | 11:18 AM
03SVTF's Avatar
As I have only been driving maybe 2 years tops and less than a year total with a straight drive(my first car was a 68 mustang with a 289 and a c-4), Much of these things are new to me, ive was never shown "double clutch" but i know a brake job is cheaper than replacing a clutch at least on my current car). Thanks for the read ill have to give that a try.
Old Jun 13, 2005 | 11:35 AM
Chevy4Life85's Avatar
Yeah IDK when people thought a clutch was a substitute for brakes!
Old Jun 13, 2005 | 06:02 PM
PaulSS's Avatar
i understand the battle of the clutches.. but this still doesnt help me
Old Jun 13, 2005 | 06:43 PM
theBLUEone's Avatar
The heat shield above my resonator rattles here and there only notice it when I start the car up and the windows are down..
Old Jun 13, 2005 | 07:47 PM
Wolfman's Avatar
this happens on my durango every now and then. Its not bad, but it mis shifts for me on my AUTOMATIC, which is really gay.
Old Jun 14, 2005 | 01:50 PM
gdavis's Avatar
Angry
Originally Posted by PaulSS
that could be it.. the sound that i would imagine that makes is the sound i hear
Don't know if they (GM) is going to have a recall on the resinator or not. Dealership is trying to locate an exhaust system for my car. Also noticed rear quater panels are loose hope I did'nt buy a lemon. They are ordering me new support brackets. one more thing an the SS is going back!
Old Jun 14, 2005 | 03:16 PM
stlurbanpunk's Avatar
yeah i have problems with mine. the rear doors always shake down too.
Old Jun 15, 2005 | 01:45 AM
PaulSS's Avatar
Sl0wbaltSS
Nov 21, 2018 11:11 PM
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
