weird noise while rpm's drop
Old Jul 24, 2009 | 12:43 AM
blackss2.0's Avatar
im not sure if its im my head because its such a quiet or mild noise i should say but ill give it a try. Seems that when i down shift or let off the gas and the rpm's are dropping i hear a slight almost grinding sound coming from the engine or tranny. Its very quite and its like an inconsistent grinding or rubbing sound right after i let off the gas for a couple seconds. any ideas?
any ideas?
Last edited by blackss2.0; Jul 24, 2009 at 12:43 AM. Reason: Automerged Doublepost
Old Jul 24, 2009 | 12:45 AM
Angel's Avatar
Sounds like the same problem I was just experiencing. We just pulled the engine and tranny to do some internal work and when the tranny was off my buddy who is a very experienced mechanic said "heres where your grinding noise is coming from" and it turned out the thruster bearing for the clutch was shot". I did have a new clutch installed and shortly after that the noise was apparent so I wasnt sure if it was normal or not. Turns out this is something that is a must to replace when doing a clutch install but the mechanic at GM who done it must have forgot. Typical ******* dealerships anyhow.lol. Anyhow, I hope this helps!
Old Jul 24, 2009 | 12:48 AM
blackss2.0's Avatar
my clutch is stock though. Was the sound very very faint and was like on and off real quickly for like 2 seconds?
Old Jul 24, 2009 | 01:46 AM
Angel's Avatar
Mine done it a bit more but sounds very similar. How many miles on your car? It might still be a possibility.
Old Jul 24, 2009 | 01:49 AM
blackss2.0's Avatar
14000 miles on the car.
Old Jul 24, 2009 | 02:09 AM
Angel's Avatar
Well mine had 7,000 when the clutch was done so it could be that. I noticed it was coming from the driver side by the tranny so it helped us locate what it was. It sounded like a grinding sound whenever I came up to a stop sign and had the clutch depressed.
Old Jul 24, 2009 | 10:50 AM
Snakes709's Avatar
holy **** u had clutch issues at 7,000? God damn...my 07 ss/sc is my first car...and only car that i've driven thats standard and i have 82,000km (50, 952miles) on it...still no issues
Old Jul 24, 2009 | 02:41 PM
blackss2.0's Avatar
yeah i don't think i have the same problem as you than Angel because i don't hear anything when at a stop. Just right after i let off the gas and the rpm's start to fall. Might not be anything i hope. Just being paranoid before i blow my warranty with stage 2 install.
Old Jul 26, 2009 | 09:49 AM
megaman311's Avatar
42k on my factory clutch with no such problems.
Old Jul 26, 2009 | 10:14 AM
Karlen89's Avatar
84,340 miles original clutch.
Old Jul 26, 2009 | 02:22 PM
GTPUSER's Avatar
30,000 on original clutch, still grabs hard.
Old Jul 26, 2009 | 05:08 PM
red06SC's Avatar
wtf how is a cltch toast in 7,000 miles?
62,000 on mine and it still grabs..
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
