Weird RPM surging
Old Jun 6, 2007 | 09:56 PM
OneFast20's Avatar
Weird RPM surging
I just changed my plugs from the irridum to the copper one step colder ngk's. Ever since then when I am driving and i push the clutch in the rpms will drop really low to where the car shakes the lights dim, and then surges up and down for a minute then it will finally stablize. It never did this before I switched plugs, I gapped them to .40 but i'm sure it isn't most accurate. Im thinking about just getting the zex plugs since they don't need to be gapped and putting them in and seeing what happens. I also changed my aem intake to an injen intake at the same time, so any ideas?
Old Jun 6, 2007 | 10:00 PM
Coblasts's Avatar
Could it be that the one step colder plugs are fouling.
Old Jun 6, 2007 | 10:01 PM
OneFast20's Avatar
I had one step colder plugs in there for about a year now, i had ngk BKR7EIX which are irriduim, and I just changed them to ngk BKR7E which are copper, so how would they be fouling if they are the same step cold that was in the car for a year now?
Old Jun 6, 2007 | 10:12 PM
Coblasts's Avatar
Take it back you added one step colder after change my plugs.
Misunderstood what you posted.
Check all your hoses ,most likely knocked somthing loose from working on the car.
Old Jun 6, 2007 | 10:14 PM
OneFast20's Avatar
ya, my bad, i guess did write that kinda confusing, i'll check everything tommorrow, but any thoughts on getting the zex plugs?
Old Jun 6, 2007 | 10:23 PM
Coblasts's Avatar
Cant help you there ,don't know muck about them.
Check out the preformance section or post there .Somebody there will know for sure.
Found this thread
https://www.cobaltss.net/forums/show...ight=zex+plugs
Old Jun 6, 2007 | 10:25 PM
xravenwingsx's Avatar
I have been having this problem too. RPM's so low the engine seems to want to die. I'm GMPP Stage 2 with ZEX plugs (triple electrode, pregapped to 040). Maybe I'll pull them out this weekend and have a look.
Old Jun 7, 2007 | 11:20 AM
Area47's Avatar
Rent me! per hour
you don't have enough to warrant colder plugs actually
Old Jun 7, 2007 | 01:11 PM
OneFast20's Avatar
I don't? I thought it was common knowledge that stage 2+ you go to a colder plug? It ran fine for almost a year on a step colder plug before.
Old Jun 7, 2007 | 01:14 PM
Psykostevo's Avatar
Sounds like your spark is not hot enough to light the fuel properly.
Old Nov 4, 2007 | 10:41 AM
stage5redss's Avatar
Exclamation same idle problem with stage 4 intense
I have a stage 5 intense installed and my car seems to be irrattic ran great for a day or 2 thenstarted doing this idle thing, not all the time just once in a while while coming to a stop with the clutch in the idle will jump around and then go real low and the car will actually die sometimes. it embarrassing i have tried to contact intense and they will not respond back i have made 10 calls and numerous emails ? I bought from them because i read they where so great. I have swap sensors from a friends car and still does it it also throws misfire codes when this happens. Any ideas
Old Nov 4, 2007 | 11:06 AM
Boostin_07_SS's Avatar
i had probles like this with the RPM surge... when i was stock... it only does it randomly... it also does it for like 20 minutes when i have the Air Conditioner on....
pull your number 1 coil.... i had problems with that....
Old Nov 4, 2007 | 11:27 AM
SJSchafer's Avatar
The problem may have been exacerbated by the new plugs, but the actual problem itself is with the stage 2 tune. People with completely stock stage 2 have the same problem when the AC is on. The reason is because when GM put together the tune, they never bothered to get the offsets right. They also zeroed out the adder table, even though the minimum linear PW on those injectors is like 1.2ms or so. If you have HPTuners, I will have the proper fueling tables for those injectors soon. Right now, all I have is basic caracterization numbers, but even those numbers show that GM had their heads up their asses when they put together stage 2. Maybe that is why they have 3 different versions of it.
What is the fix for now? I'd say, put your stock plugs back in.
As far as the intense tune, what injectors do you have?
Old Nov 4, 2007 | 08:05 PM
i have 60s with the C/A stage 6
Old Nov 4, 2007 | 08:33 PM
SJSchafer's Avatar
Hmm. I haven't seen the CA stage 6 tune. How do your 60s do at idle? I have seen intense tunes though. As far as the 60s tunes from them... well, old school - flatline the IFR table and make it up in the VE table.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Trav3480
Sep 28, 2015 02:46 PM
Infamous SC/SS
Sep 4, 2015 05:33 PM
