110 Octane Can our SS/SC use it?
Old Nov 4, 2007 | 01:13 AM
AaronSS06's Avatar
Exclamation 110 Octane Can our SS/SC use it?
I drove passed a gas station the other night and the sign said torco racing fuel so i stopped to check to see how much a gallon was just for the hell of it. It was 5.99. But my question is can our cars use 110 Octane? Without any problems or damaged caused?
Old Nov 4, 2007 | 01:14 AM
halfj99's Avatar
make sure its unleaded
Old Nov 4, 2007 | 01:19 AM
AaronSS06's Avatar
Its Not Unleaded.
Super_SS's Avatar
i wouldnt recommend it...i used to 4 times since i got my cobalt,and now i have a clogged cat..but i noticed a diffrence on my car...expecially on the highway when u go into the triple digits
Old Nov 4, 2007 | 01:21 AM
AaronSS06's Avatar
What would be the effects of using a leaded fuel?
Old Nov 4, 2007 | 01:23 AM
Super_SS's Avatar
uhmm..i think boom goes the balt
Old Nov 4, 2007 | 01:55 AM
Sharkey's Avatar
the lead will leave deposits on the valves, foul o2 sensors, clog cats, ect. i highly recomend avoiding leaded fuels.
110 octane unleaded would work, however without tuning for it your actualy going to hurt performance
Old Nov 4, 2007 | 01:59 AM
AaronSS06's Avatar
thanx for the warning. good thing i didnt fill up.
Old Nov 4, 2007 | 06:49 PM
rob1544's Avatar
I wrote GM and asked about this because I know a place that sells 110 octane unleaded racing fuel.
GM said it would NOT void my warranty if I used it. They said the octane must be above 91, but there is no upper limit.
I think it gives an extra kick, but not really sure.
Old Nov 4, 2007 | 06:51 PM
WSFrazier's Avatar
Unless you tuned for it, all it's going to do is prevent any knock. With a stock car, I doubt you were getting any knock anyway. So there will be no difference.
Old Nov 4, 2007 | 06:53 PM
ItalianJoe1's Avatar
It shouldn't make a difference unless you tune for it. Octane basically slows down the flame front in the CC when the spark ignites it. On a stockish car, you won't see much change, you could actually lose power due to a similar effect as retarding timing. I know when I've run 104 and the nitrous, you can actually feel the difference. Car loves that ****. Its a little expensive though, anything over 100 octane unleaded is about $8-10 a gallon around here.
Old Nov 4, 2007 | 06:56 PM
ssmokin's Avatar
i use vp ms 109 unleaded race fuel everytime i goto the track. car loves it. i get no knock whatsoever. you can mix it also with any other unleaded fuel. im not tuned for it but it helps performance a lot. hurts performance? hell no! if you were tuned for it you could pull more timing and gain quite a bit. all in all way better then 91 or 93.
WSFrazier's Avatar
I can get 112 unleaded for 3.99/gallon IIRC.
Old Nov 4, 2007 | 06:58 PM
SS_Ry's Avatar
you realize they probably kept note that you were looking for "RACING" fuel.....
Old Nov 4, 2007 | 07:11 PM
-Jayson-'s Avatar
there shouldnt be a person on here who is modifying a boosted car and not know how octane effects an engine. . .leaded? are you serious?
Old Nov 4, 2007 | 07:15 PM
memphisr24's Avatar
Just on 100 octane, I was able to hit 24 degrees of timing...From a tune that ran 15 on 93....the car hauled...but the 100 by me is like 8 bux a gallon now
Old Nov 4, 2007 | 09:09 PM
IMADreamer's Avatar
For those of you who think running race fuel is helping your performance it's all in your head. I'm sorry but it is. If you think different it just shows your ignorance of the subject. Higher octane only has a greater resistance to knock and has nothing to do with horsepower. It's a big myth that sadly a lot of people here believe.
Unless you are tuned race fuel is just a waste of your money.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Hugger1975
Oct 15, 2015 03:28 PM
Bluelightning
Sep 8, 2015 05:18 PM
