weird supercharger noise
Old May 10, 2007 | 08:45 PM
braddddddd991's Avatar
my supercharger sounds like it's almost grinding something in the inside of it.
Is this normal?????
Old May 10, 2007 | 09:46 PM
tkaugh29's Avatar
haha nooooooooooo. it should have a heavenly whistlie like sound
Old May 10, 2007 | 09:59 PM
Acidangel_5.0's Avatar
bearings going bad.. get it fixed pronto
Old May 10, 2007 | 10:03 PM
Shortbus's Avatar
No grease ftw! You need to take it to the dealer if you under warranty or have a gm pulley on the blower, if not take that bad boy off the car yourself make sure the bearings are still in a straight line and not bad, and you can just re-pack them with grease.
Old May 10, 2007 | 10:05 PM
SKDR112888's Avatar
nononono roots type blowers make noises that dont sound to good but are normal.
what exactly does it sound like......
Old May 10, 2007 | 10:23 PM
silversccoupe's Avatar
I don't know what yours is like ,but mine sounds like it's full of marbles.Kind of like a diesel almost.Glad I'm not the only one with paranoia
Old May 10, 2007 | 10:26 PM
p7x's Avatar
p7x
mine has had a grinding sound from day 1, if it's a very loud or inconsistent sound than you have a problem.
Old May 10, 2007 | 10:29 PM
Smarty Art's Avatar
If there are no performance problems then I'd let it go. If the bearings go then you'll have a problem. I'm guessing its the coupler. It connects the snout to the roter gears. It wears and vibrates.
Old May 10, 2007 | 10:34 PM
BOOSSTED 06's Avatar
yeah this is the same thing we all hear. roots blowers are loud per say. Mine sounds the same way and always has. I am paranoid as well
Old May 10, 2007 | 10:41 PM
My car has all of 1500 miles on it,so I don't think it's a wear issue.The only time I hear it is when the hoods open.So my solution?close hood.I've had some experience with roots blowers but only of the 6-71 and 8-71 variety.
Old May 10, 2007 | 11:07 PM
Mikey851's Avatar
Yeah, roots blowers will do that. Mine does it, but is just barely louder than the tick of the injectors.
Old May 10, 2007 | 11:08 PM
Mikey851's Avatar
Old May 10, 2007 | 11:13 PM
ggarcia86's Avatar
i think its the throttle body... haha cause mine went bad and had to be replaced, it kept making sounds at idle that made me cringe, i put an automotive stethescope up to the throttle body, mainly the actuator and that where the strongest sound was, of course the gm tech wouldnt take my word for it and had to diag it but thats when i had my bumper to bumper anyway so free tb yay! new one didnt match the s/c like the old one but oh well...
Old May 10, 2007 | 11:41 PM
Mikey851's Avatar
Yeah, maybe yours did that, but we're just saying that roots blowers are known to make a little noise.
Old May 11, 2007 | 11:20 AM
Ramps's Avatar
I have the common random clicking/rattling sound when it's warm. Sounds like marbles bouncing around in there...i heard it's the SC coupler or something...but who knows. It never makes the noise when i bring it in...and the dealer denies ever hearing the cars make that noise, they also say our chipping wheel paint doesn't happen either...
Old May 11, 2007 | 11:23 AM
JonyyB's Avatar
Site Founder
It's normal. here is a vid:
https://www.cobaltss.net/forums/show...ighlight=noise
and see this:
Old May 11, 2007 | 02:13 PM
its only at idle
Old May 11, 2007 | 05:49 PM
ggarcia86's Avatar
Originally Posted by braddddddd991
its only at idle
take it to the dealer and say "i think the throttle actuator is bad on my throttle body, its making a nasty noise at idle" they might send someone out right there to listen to it, and then they will say, "we need to bring it in and diagnosis it." then they will call you up later and say that they need to order a throttle body haha. or if thats not the issue the tech should figure out what the noise is for himself and fix it under warentee
Old May 11, 2007 | 05:58 PM
Psykostevo's Avatar
Not likely, couplers last a long time.
Old May 11, 2007 | 06:07 PM
blueta's Avatar
Not really. They can go bad pretty quickly in some cases. Some have replaced them and acutally went bad within a month. Simple test. Take the belt off the blower pulley. Grab the pulley and turn it back and forth. If you feel ANY slack before it catches then it's the coupler. Very easy to change. You'll need some bottles of supercharger oil, and to drain/fill the supercharger go to CVS and get a syringe (no needle) and a short length of vac line to fit over the end. Suck and fill But seriously, it's a very simple test that takes a minute to do. At least it eliminates one thing.
Old May 17, 2007 | 06:26 PM
ggarcia86's Avatar
braddddd any progress? is your car good yet?
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
